Old 23rd June 2008, 11:34 PM   #1
ambience exists's Avatar
Default Simple tube phono stage
Hello World,
I am looking for a schematic of a very very simple tube based phono preamp that would pair nicely with my S-5 Electronics K-12 tube amplifier.
It would be nice to have a power supply diagram as well!
((AE))
Old 24th June 2008, 12:15 AM   #2
Phono preamps are among the most difficult of projects to execute. A suitable circuit is not sufficient. Great care in mechanical layout is a must too.
If you are adamant about building a tubed phono preamp, I suggest you look at the Bottlehead Corp. Seduction kit. You'd have reasonable prospects of a successful outcome.
Frankly, the K-12 isn't good enough to benefit from such a high quality source. The opamp based Hagerman Bugle is quite adequate as source for a K-12.
Eli D.
Old 24th June 2008, 10:37 PM   #3
Thanks a lot, I realize that the K-12 isn't an Audio Note Gakuon or anything!
Are there any other cheap solid states I could look at?
((AE))
Old 24th June 2008, 11:54 PM   #4
diyAudio Senior Member
fdegrove's Avatar
If you're looking for a SS phono then why put you quest in the tube section?
Before you design or ask about a simple phone preamp_ they do exist_, why don't you tell us what your cartridge is, what the Zin of your amps is and how long the IC is you plan on using with it? And what you expect from the preamp?
Frank
Old 25th June 2008, 12:24 AM   #5
astouffer's Avatar
The RJM phono stage worked well for me.
http://www.geocities.com/rjm003.geo/.../diy_pho3.html
Old 25th June 2008, 05:18 PM   #6
jduffy is offline jduffy  United States
jduffy's Avatar
Personally, I'd build the Hagtech Cornet2. You can do it on the cheap if you're careful and the sound is amazing. It's also a very simple build as it's on a circuit board as opposed to point to point.
Just a warning though, purists don't consider a phono preamp on a circuit board to be a proper phono preamp. They believe for best sound it has to be P2P. Me? I love the Cornet2. The thing sounds simply amazing.
If you build the Cornet2 you won't need another phono preamp probably for a long time to come.
Good luck with your decision.
Old 25th June 2008, 06:48 PM   #7
Shoog's Avatar
http://www.geocities.com/rjm003.geo...o/diy_pho3.html
Very good. I built one with a OPA627.
I heard a build with top flight components which put my tube based one to shame. Extremely easy to build, though not that cheap if you opt for the OPA chips. Texas instruments are quite easy to get sample out of though.
Shoog
Old 26th June 2008, 07:59 PM   #8
We should probably continue this on the SS forum before we get hurt...
((AE))
Old 27th June 2008, 02:29 AM   #9
Tubed or SS, a high quality phono preamp is going to be wasted, when connected to an amp that's not much better than a toy.
AAMOF, the Hagerman Bugle is better than the K-12 deserves.
Eli D.
Low-V simple phono stage + tube buffer iko Analog Line Level 0 12th October 2008 12:45 PM
Simple phono stage (MC) Onvinyl Analog Line Level 5 9th August 2008 09:50 PM
tube phono stage dsavitsk Tubes / Valves 10 15th December 2006 12:26 PM
The NSSPS (Not So Simple Phono Stage) dsavitsk Analogue Source 10 15th November 2005 04:52 AM
Rjm simple tube phono pre ebijma Tubes / Valves 2 29th September 2005 05:03 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
