| diyAudio Sponsor | ||
OK, here is an obscure one for you. I am planning a 6EM7 based integrated amp with phono. I wanted to try the old trick of putting the phono tube heaters in the output tube cathode circuit but the likely operating point for the output tubes is 50mA each = 100mA total. My initial choice of tube was the 12AY7 but it requires 150mA.
I had thought to use a bleeder resistor to supply the remaining current from B+ but that would be a whopper of a resistor and would be pushing the current limits of my transformer. Well in flash of inspiration I decided to turn it around and see if there were appropriate phono tubes that required either 100 or 50mA heater current. Using Duncan's search capability I came up with a list of suspects which I have narrowed down (eliminated things like remote cutoff pentodes and power tubes etc.) to the following possibilities. 18FY6 Triode Dbl Diode u=100 $4.95 18GE6 Triode Dbl Diode u=70 $3.00 18GD6 Pentode $9.95 All have enough gain to be considered a possibility. Is anyone familiar enough with these tubes (or other possibilities that I missed) to opine as to their suitability for phono preamp service. Factors such as noise and microphonics are of course important. mike |
#2 |
Mike,
Aside from the fact that the "Cheap Charlie" method of obtaining heater DC STINKS, you are overlooking the fact that 4 triodes are needed to complete a stereo phono section. Building a 300 mA. regulated 12 VDC supply that supports a pair of 12AX7s is easy. Voltage double, using Schottky diodes, the O/P of a 2 A./6.3 VAC winding. Follow with a 7812 3 terminal regulator.
Eli D. |
#3 |
Thanks Eli;
I hadn't forgotten that four triodes were needed but I have plenty of real estate on my chassis and I need to drop 150V on the cathodes of the output tubes anyway. I would be interested in what stinks about that approach. Being SE the DC would be pretty clean and the audio signal would be smaller than the AC on a normal heater supply wouldn't it? Heaters would be at higher potential than cathode. Not being argumentative, really want to take advantage of your insight.
mike - www.keepingsundayspecial.org |
#4 |
20EZ7: 100 mA equivalent of 12AX7 or 6EU7. Not plentiful, but cheap when you can find 'em... UCC85 is even harder to find - think of it as a 26AT7.
I'd use separate cathode resistors for the rest of the bias, as it will be self-adjusting to a degree. Common cathode resistors need matched tubes. |
#5 |
Thanks for the information. I think I may build the amp without phono for now using big power resistors to drop the 150V at the cathodes. I can then build the phono amp separately and/or add it later if I want to experiment with that. This gives flexibility and allows me to get the most important stuff going quicker.
mike
| stereo push pull amp one heater supply for power tubes | nhuwar | Tubes / Valves | 5 | 3rd February 2007 02:32 AM |
| Why separate AC heater supplies for driver and power tubes? | leadbelly | Tubes / Valves | 3 | 5th March 2006 12:34 PM |
| psu to heater on 4 el34 tubes??? | wuffer | Tubes / Valves | 7 | 15th December 2005 08:55 PM |
| 100mA CCS? | Bricolo | Parts | 12 | 22nd February 2004 07:56 PM |
| Balancing output tubes by changing heater voltage. | Circlotron | Tubes / Valves | 8 | 10th February 2003 11:15 AM |
| Page generated in 0.07593 seconds (76.73% PHP - 23.27% MySQL) with 10 queries |
