does lower B+ cause scratchy distortion?
Old 20th June 2008, 11:13 PM   #1
PRNDL is offline PRNDL  United States
Default does lower B+ cause scratchy distortion?
I have a PA amp conversion from a small Dynavox amp that used a pair of 6AQ5's, which I switched to 6AK6 or 6AN5 to lower the power and volume to around one watt.
The design is based on the Matchless Spitfire (one gain stage with a LTP PI), which has a B+ of 350, which is significantly higher than this amp (289).
The amp now has a scratchy distortion when the volume is at about 8-9 that occurs when notes are played. It's very apparent with low E notes. This is high enough volume to cause the amp to distort (for rock and roll). At lower volumes, it's nice and clean without issues.
I've gone bananas changing and testing components and the scratchy distortion remains. I've swapped tubes and put in a different output transformer.
I'm wondering if there's a design flaw in the amp, especially with the phase inverter.
Here are the voltages:
V1-6 = 160
V1-8 = 1.1
V2-1 = 177
V2-6 = 173
LTP center = 48
V3/4-7 =
16 w/280
24 w/400
The 400 ohm cathode resistor was used to lower the bias on the 6AN5's. At the time I thought the output tubes were way too hot. That wasn't it.
The PI has about 80 volts to the B+ (250 - 170), which seems to be plenty.
I'm pretty ragged now ... this little amp is a tough nut to crack!
Any help is greatly appreciated!!!!
does lower B+ cause scratchy distortion?Hide this!Advertise here!
Lower rails for lower impedance? 95Honda Solid State 7 19th December 2007 08:59 AM
Aleph L with huge distortion at lower settings? panos29 Pass Labs 3 15th May 2006 08:28 PM
Lower Distortion Alternatives to 12AT7 & 12AU7 ? DrDeville Tubes / Valves 19 20th May 2004 10:45 PM
Excel W12 lower distortion than W15?!? capslock Multi-Way 0 24th February 2004 11:34 AM
Bootstraping Op Amp substrate for lower Distortion ppl Solid State 10 25th June 2003 09:29 AM
