diyAudio Sponsor
Old 20th June 2008, 10:35 AM   #1
Default To choke or not to choke
Have been modeling some options for PS filters for my SE 6EL7 amp project. My PT has 327V and 265V taps so I can get very similar output voltage and ripple performance using CLC or CRCRC (only need CRC for the single channel test circuit but extra stage necessary for stereo version).
So the question is, if I can get the same ripple performance (target I have in mind is 300V with 400-500mV ripple) with either method is there any sonic advantage to one over the other? Any stability advantages?
mike
Old 20th June 2008, 02:43 PM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
The LC version will probably have lower output resistance, which will reduce crosstalk if two channels share the same supply. In theory, LC is quieter but it usually needs some snubbers. Make sure you've checked the peak choke current.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 08:30 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 11:05 AM
L as a choke. bogdan_borko Solid State 9 9th September 2006 09:48 PM
SS PSU without choke Mikael Abdellah Tubes / Valves 29 15th January 2003 04:34 PM
Page generated in 0.06665 seconds (66.82% PHP - 33.18% MySQL) with 10 queries
