diyAudio Sponsor
Old 20th June 2008, 12:26 AM   #1
rdf is offline rdf  Canada
rdf's Avatar
Default Very low current CCS?
Anyone have experience with <1 ma solid state CCS plate loads? I'm about to grievously abuse an MC240 I've had for 25 years and the front end 12ax7 by my calculation runs at 200 uA Ip on a 100K plate load. It seems the obvious place to start. Thx in advance for any suggestions.
Ears aren't microphones.
Old 20th June 2008, 11:15 AM   #2
Hi
Morgan Jones (3rd edition) presents a diff pair with an ECC83 with plate loads consisting of MPSA92 transistors set for about 0.4mA (6.2V reference / 16000k), so I assume it could work for loads <1mA...
Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 20th June 2008, 01:10 PM   #3
Gary P's Avatar
Try using cascoded Supertex LND150 MOSFETs. I use them for generating the bias voltage in the self bias CCS (Q2 and Q4) where they run at ~300ua. Very good performing parts. Adjust the value of the 2.2K resistor (R17) up a bit to get 200ua.
Gary P's DIY page
Old 21st June 2008, 03:24 AM   #4
rdf's Avatar
Thanks all. The LND150 caught my notice and looks a nice fit for my stock of dsavitsk's PCBs but I couldn't find anyone using them solo as CCSs. Much appreciated!
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
Current rating and tube current draw cbutterworth Tubes / Valves 1 13th October 2006 04:42 AM
Using Ixys current regulator as current sink. G Solid State 3 16th November 2002 10:23 AM
R21? and Current Source AC Current Gain macka Pass Labs 9 20th May 2002 08:58 PM
Page generated in 0.07364 seconds (70.07% PHP - 29.93% MySQL) with 10 queries
