Old 9th July 2008, 07:34 AM   #61
oldeurope is offline oldeurope  Germany
Default #60
Hello jane,
QUOTE]Originally posted by jane
What are the main differences between the "gyrator" stage in your drawing and an ordinary mu-follower?
Jan E
[/QUOTE]
The gyrator replaces a coil ll resistor in my drawing.
A mu-follower provides -gain.
Strange question, is this a pitfall?
Darius
Old 9th July 2008, 11:54 AM   #62
jane is offline jane  Norway
jane's Avatar
Default Re: #60
I suppose you could say the same thing about a follower?
In a mu-follower with fixed bias the driver tube will see ~Ra as the load at f<<fc and ~(Ra x mu+1) at f>>fc. You may replace the upper tube in this follower with a coil with Rdc=Ra and a parallel resistor Rs=(Ra x mu+1).
Jan E.
Life is hard - Then you die.
Old 9th July 2008, 01:23 PM   #63
On Hiatus
SY's Avatar
Jan, I had never thought of a mu follower as a gyrator before, but that makes perfect sense.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 9th July 2008, 03:10 PM   #64
Default #62 #63
Ok, let's feed the troll.
Originally #62 posted by jane
http://www.glass-ware.com/tubecad/TP1.gif
In a mu-follower with fixed bias the driver tube will see ~Ra as the load at f<<fc ...
Jan E.
In this case, it isn't a mu-follower.
In a mu-follower with fixed bias the driver tube will see...~(Ra x mu+1) at f>>fc. You may replace the upper tube in this follower with a coil with Rdc=Ra and a parallel resistor Rs=(Ra x mu+1).
Jan E.
The question here is:
Is (Ra x mu+1)>> ra of the bottom tube?
In this case it is a mu-follower.
In my circuit (Ra x mu+1)<< ra,
thus it isn't a mu-follower.
http://bp3.blogger.com/_oCEpds9YoPw/...Darius+001.png
http://line-pre.blogspot.com/2008/07...eamp-2008.html
If you want a technical discussion, you must give more detailed
information. But I am sure you and SY do know this.link
The following picture gives an example.
This is a mu-follower:
http://bp0.blogger.com/_oCEpds9YoPw/...008_Darius.png
http://line-pre.blogspot.com/2008/07...ninverter.html
Kind regards,
Darius
Old 18th September 2008, 01:56 PM   #65
Default @ Don
Originally #23 other threadposted by smoking-amp
sorta OT: Say Darius, I recall you were looking for a tube with a Mu of 1 a while back. I just ran across a data sheet that mentions just that (bottom 1st page):
http://www.mif.pg.gda.pl/homepages/f...093/6/6AH6.pdf
But probably rather high rp with this tube. Could try g3 drive with some low rp pentode instead.
Don
Thanks Don
Kind regards,
Darius
Unity gain inverter emogstad Chip Amps 1 10th June 2009 03:09 PM
Phase inverter ThSpeakerDude88 Tubes / Valves 37 29th August 2007 03:15 PM
6C8G phase inverter engels Tubes / Valves 4 4th February 2007 06:01 PM
Unity buffer from 7-pin triode? aletheian Tubes / Valves 11 16th December 2006 10:40 PM
Copyright ©1999-2017 diyAudio
