Old 21st June 2008, 08:43 AM   #11
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Originally posted by Wavebourn
...utilizing Miller capacitance for good.
That's what I thought was so clever about the Neumann microphones.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 21st June 2008, 09:39 AM   #12
Send a message via MSN to Makofoed-6sn7
Hi there!
And don't forget the Hammond organ:
http://captain-foldback.com/Hammond_...atics/ao28.jpg
The volumepedal is conected thru a rod up to the preamplifier where it controls the var.cap.
That circuit replace'd the early version with a resistive divider that were shorted together as you hit the pedal( alitte noisy and had a wrong "feel"). There are no hum/noise whats so ever with the capasitiv volume controll.
Best regards,
Magnus Kofoed
The line under is true
The line above is false
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Variable Voltage Volume control jkeny Power Supplies 4 10th February 2008 09:13 PM
Volume control : - pot' or pot' variable feedback resistor (gain) ? ash_dac Solid State 5 1st August 2006 05:07 AM
Subwoofer variable phase control AudioFreak Solid State 23 18th July 2004 03:54 PM
Variable power supply to control gainclone volume? MWP Chip Amps 11 9th July 2004 08:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
