| diyAudio Sponsor | ||
Have you any idea about this pentod, I mean 837 tubes.
Nothing information at all... I have tryed search here and google too. I want to make SE amplifies based on this tube. Can anybody help me with 837's in triod curves? May be you get me your personal opinion about triod mode for this tube. PS Typical datasheet I already have! I ask about triod curves! |
#2 | |
I would have gone for a more available valve. Otherwise when the valve finally wears out you will have trouble getting another one.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
It is an answer, but not for me! I have others target, it is not me first aplifier.
I want to "cook" this one! |
#4 | |
John |
#5 |
http://www.mif.pg.gda.pl/homepages/f.../049/8/837.pdf
here's a datasheet if you haven't found one yet. tube looks really good, please report about build progress. |
#6 | |
If you use a 12AX7 / ECC83 then the curves are in the data sheets. Pretty much most guitar valve amps have 12AX7's on the front end so there are bags of examples for circuits. I used this valve on a mixer pre amp and it gives very good results. I have 3 clean channels and a high gain channel that gives great distortion for my guitar.
#7 |
hey-Hey!!!,
Why restrict yourself to running the 837 strapped as a triode? With some attention to its curves, it will work well as a pentode, or even properly proportioned Ultra-Linear( get the tap placed in the right spot, that is ). cheers, Douglas
the Tnuctipun will return |
#8 |
Im not sure the screen would like UL. The max rating is listed as 200V? Whether this tube can be pushed in that regard I am uncertain.
Be sure your foil hat has a good low impedance ground. |
#9 | |
cheers, Douglas
#10 | |
There you can find some suggetion for using in SE. (in attach) |
| Tube SE amplifier with 6P3S (russian tube) | danzup | Tubes / Valves | 46 | 12th April 2012 08:35 PM |
| Page generated in 0.09821 seconds (78.21% PHP - 21.79% MySQL) with 11 queries |
