| diyAudio Sponsor | ||
Dear fellow DIYers,
I recently joined the word of tube and wanted to start my first headphone amp. project with the optimized morgan jones design. ref: http://www.headwize.com/projects/sho...=cmoy5_prj.htm One problem that I came with is there is an option for a output transfomer. During my research, I found out transformer at the output stage is considered more suitable for tube amps. I know usually the secondary impedance is 4 or 8 ohms (fine, typical speaker impedance), but I have no idea what is the usual input impedance value? I saw some are 3.5K where some are just down to even 600 ohm. My question here is, what actually determines the primary impedance of the output transformer? Is it the ratio of primary and secondary volage or something else? If I custom made some output transformers, could the secondary impedance have some value other than 8 ohms? Thanks very much for your input, James |
#2 |
Hi
Transformers 'reflect' an impedance from one side to another, in a ratio determined by the turns on the primary and secondary. The voltage ratio from one side of the transformer to the other is Np/Ns And the impedance ratio is the above ratio squared so for example if you have an output transformer with a 10:1 voltage ratio, it has an impedance ratio of 100:1 therefore if you connect an 8 ohm impedance to the secondary, a speaker say, it reflects back 800 ohms on the primary. Similarly, an impedance ratio of 1000:1 would reflect a 8000 ohm load on the output tubes if an 8 ohm speaker were terminated on the secondary. Manufacturers provide addition taps/windings etc, to maintain 8000 ohms on the primary, when 4 ohm speakers need to be used. does that help? |
#3 |
diyAudio Moderator Emeritus
A transformer doesn't really have a primary or secondary impedance. The impedance of the primary is determined by the impedance of the load on the secondary multiplied by the square of the turns ratio. So if, for example, you have an 8 ohm speaker across the secondary and the primary turns = 20 x the turns on the secondary, then the primary impedance = 8 x 20 x 20 ohms = 3,200 ohms. If you put a 200 ohm headphone on the secondary, the primary impedance will be = 200 x 20 x 20 ohms = 80,000 ohms.
In general, output transformers are made for speakers and are unsuitable for headphones. The few that are on the market for phones are expensive. One way out is to use a speaker transformer with a dummy load (e.g. an 8 ohm 15 watt resistor), and then connect the headphones in parallel with the dummy load, maybe with a series resistor to limit the signal voltage delivered to the phones for protection. I've seen an example on this site. Another way is to use a toroidal mains tranformer of the required turns ratio (voltage ratio). Toroids have good bandwidth and some people say they work well for phones. Yet another way is to make your own transformer, as you propose. |
#4 |
Whoa, watch out... While it is true that transformers reflect impedances, the impedance they can reflect is finite, and is as a simplification limited by the primary winding reactance on the low end, and leakage inductance on the high end.
When the reflected load impedance becomes a significant % of the winding reactance at a given frequency the distortion will start to increase as the now none ideal transformer's primary reactance appears in parallel with the reflected load. This limits the highest impedance that can be matched, and is also a fact of life that limits LF extension in all audio transformer applications. You can see this effect as the -3dB response moves higher with increases in load impedance. (No global negative feedback applied! Triode amplifiers also exhibit slightly different behavior in this regard. The assumption I make here is that the transformer is driven by a non ideal voltage source with a relatively predictable source impedance or is driven by a current source such as a pentode.) Leakage inductance is a parasitic inductance that appears in series with the primary and has the effect of limiting HF response, in this case as the reflected load impedance decreases the effect of the leakage reactance becomes more pronounced - also the case as the frequency goes up as the effective leakage reactance also increases. (Worst case here is low source impedance and load impedance.) These are just two non-ideal behaviors that limit a transformer's ability to transform impedances. DCR obviously also plays a role as does the core's magnetic properties. I haven't probably explained this all that well, but hopefully I have added something for further discussion. In terms of MJ's headphone amplifier a limited ratio of 2:1 is probably more than enough to accommodate real world headphones as this would reflect 32 ohms to the amp for an 8 ohm headphone and about 250 ohms for a 64 ohm set of phones. Voltage compliance is probably the practical limit for choosing a transformer here. For 32 ohm phones and up a transformer is probably not required.
www.kta-hifi.net |
#5 |
The transformer in this design is only needed for low impedance headphones.
Do you already have headphones that you want to use? If so, do you know their impedance? It would be good to actually have a plot of impedance vs frequency. The selection of an appropriate output transformer depends on this impedance curve. P.S. please also note the voltage rating on that output cap. This is very important for your safety! Adding an output transformer will also improve the safety by providing additional isolation from HT. |
#6 | ||
billr
Yeah, your answer definitely helps. So I understand the transformer does not really have anything to do with impedance expect it firstly bring down the source output voltage to an appropriate level suitable to drive the speaker, and the impedance is really the side effect. As a result, a 3.5K : 8ohm output transformer is just saying a 20:1 turn ratio in another way?? ray_moth yeah, I have seen many topologies using dummy load method, but isn't it more appropriate to use 8 = Rdummy*Rheadphone/(Rdum+Rhp) to calculate the dummy load because we can give a better impedance matching? kevinkr Quote:
Iain Quote:
Again, thanks for all the inputs. So glad that I can learn so much here! James |
#7 | |
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#8 |
pkjames
To determine just which OPT you want to obtain, you have to consider the actual working load that the transformer provides to the tube. Reflected load is one component. The RP or plate resistance is another part and the actual DCR of the OPT primary is the last part. If you add the reflected impedance (Rl) in parallel with the Plate resistance (Rp) and then add that sum to the primary DC resistance of the OPT as a series added resistance, you will have the complex impedance load that the OPT primary must provide to the tube plate. To determine which transformer will meet this load, divide this impedance by 2 X pi and the lowest frequency of interest (i.e. 20Hz). This will provide the amount of inductance you need in the primary. But, this will only provide for a -3dB performance at this point. To obtain a -0.5 dB performance you must have 3.63 times this calculated inductance. But, you only need this amount as a maximum performance number, under load and making music. Now, most inductance values quoted are at a minimum flux point of 1 vac and 120 Hz. A gapped core transformer rated to handle 20 to 40 ma DC will typically have twice this measured inductance, as a maximum amount. An un gapped transformer will typically have 10 times this amount as a working maximum. For SE you must have a gapped transformer. So, when looking, make sure you know what the expected primary inductance is and how they arrived at that number. Is it measured at 1 vac & 120 hZ, as most mfg's supply, or is it the maximum loaded operating number, as Lundahl typically provide? Then you need to determine the plate DC current that will pass through the OPT primary and make sure the OPT is designed for pretty close to this amount, not more than 1.5 times that current number. If this doesn't click in your head I can do the math for you too. But I think you should go to Franks Tube Data, down load the appropriate tube data sheets and struggle with this actually fairly simple problem, so you have it down cold, for future projects. Bud |
#9 | |
I think it's better to think of it that the headphones are too big a load for the tubes to drive direct so a transformer converts the low impedance headphone up to a nice high impedance for the tubes to drive. There's no magical formula other than laws of physics, but some transformer ratios will be better than others for your application. You either model all the variables or tune by ear (or both) |
#10 |
Thanks very much guys,
I will probably sit down to play around with the math suggested by Bud, it is definitely a good idea sort out this math problem for the sake of good! Thanks again guys! |
| 6n6p transformer output impedance | jungle1971 | Tubes / Valves | 1 | 13th April 2009 06:16 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| output transformer impedance choices | Curly Woods | Tubes / Valves | 3 | 24th January 2007 11:26 PM |
| Output transformer Impedance | NickC | Tubes / Valves | 6 | 9th May 2003 05:27 PM |
| Page generated in 0.15511 seconds (91.48% PHP - 8.52% MySQL) with 11 queries |
