diyAudio Sponsor
Old 15th March 2003, 01:33 PM   #1
Default 2nd & 3rd Harmonic Distortion curves for 5B/255M (807)
I have been playing with a design for a friend using 5B/255M valves. These are basically a loctal version of 807 beam power tetrodes. My initial design and breadboard was a PP amplifier and it performed very well - but I thought I should knock up a SE version to compare with, in case he prefered that. The SE was not bad but was clearly worse than the PP. To try and see a little of what was going on here I measured the distortion in both modes and found the PP to be much, much lower for 2nd harmonic and about half as much third harmonic too, so I'm not surprised that the PP sounds better (in this case).
So then I thought I would try the out of fashion Tetrode Class AB2 PP just for fun. So I tweaked it to Class AB2 added a smidgeon of feedback (6dB) and sat down to listen.... I was very surprised! It sounds really good. Actually really really good! Close to the A1 pp and better than the SE! So to measuring again. Surprise it has a nice distortion spectrum! Second higher than A1 PP but much less than SE, third nicely less than second... hmm...
My speakers are fullrange about 7ohms impedance in a reflex cabinet and about 95dB sensitivity. Source battery powered CD player. All amplifiers fixed bias and IT interstage. Driver tubes 6N6P. PP amps are PP throughout.
Here is the graph of the measurements.
Old 15th March 2003, 03:42 PM   #2
Brett's Avatar
Hi James,
Interesting post, and one which basically tallies with both what I've read, and what I've measured myself in the past. The 807 is one of my fave tubes (I have boxes of them in all flavours). The STC 807 datasheet (5.5M) might be of interest if you haven't already seen it. Excellent data with lots of graphs of different output stage configurations and distortions for 2H and 3H
If you have the facilities, it's very interesting to note the higher harmonic content in the different configurations, and how they change with level.
I'd be interested in seeing your schem for the A1 PP if that's possible.
BTW: do you have a source for 6N6P's? I've been trying to get my hands on some to try for a while now.
Cheers
Old 15th March 2003, 05:32 PM   #3
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Crossover distortion?
Interesting. Were you able to measure distortion at lower levels with the AB2 configuration? And, what Ra-a did you use? (I have some 5B/255Ms, you see.)
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th March 2003, 06:34 PM   #4
Hi Brett,
I hadn't seen that data set for the 807. Nice document! Thanks for the reference.
I had shown the schematic for the A1 pp in this thread
Simple IT PP . The input pot into the input transformer is not an optimum design...but it works after a fashion. I'm having some multiple tapped autotransformers built to tryn as a TVA (I guess AVA, or ATVA) for the real version.
On test I ended up changing the OPT tap to make it Ra-a=7K instead of the 11K shown in the diagram. Otherwise it's as shown. The pp balance pot was adjusted for best sound which was also minimum distortion ( as near as makes no difference) and it was with about 8% dc imbalance...
I have a great source for all sorts of valves. It's a chap in Germany, here is the URL
Ask Jan First . Jan is a great chap and very helpful. Please mention my name if you use him.
Hi EC8010
The Ra-a was 7.5K also in AB2. I didn't measure any other harmonics as my kit at home doesn't do it. I guess I could take it into work and put the Spectrum analyser on the output... Work is a bit busy at present so it might be a couple of weeks before we get to that. I'm curious as to the extent of crossover distortion and to the upper harmonic signature too. Through my speakers I doubt I pushed it beyond 10 watts at most. I was surprised at how relaxed it sounded and how good it's imaging was. I'm very impressed with the 5B/255Ms. BTW I didn't run them very hot - only 450volts on the anode and 250 on the screen grid. Also after 40watts the 3rd harmonic climbed away but the second had peaked and dropped down by about 30% after that...
ciao
James
Old 15th March 2003, 08:22 PM   #5
EC8010's Avatar
Default Spectrum analyser
Hello James,
very few spectrum analysers have the resolution to look a long way down on their own, but if you hang the spectrum analyser off the oscilloscope output of the distortion analyser, it adds the dynamic ranges together. This subterfuge allows me to look reliably down to -90dB, and occasionally further, limited primarily by oscillator purity.
Of course, at this point, you start thinking, "Wouldn't it be nice to have an AP System 2, or even a 1, surely they are due to turn up second-hand soon. Please?"
Hello Brett,
my (extremely lethargic) printer is starting to think about the possibility of printing the first of the 43 pages of 807 data sheet. It looks like a real gem - thanks for the link.
Old 15th March 2003, 09:45 PM   #6
diyAudio Senior Member
fdegrove's Avatar
Default RAIN FORREST.
EC...mind the Rain Forrest.
Frank
Old 15th March 2003, 10:19 PM   #7
EC8010's Avatar
Default Re: RAIN FORREST.
Originally posted by fdegrove
Mind the Rain Forest.
Hello Frank,
that's terribly 80s of you! In the 90s we worried about skin cancer due to the hole on the ozone layer. This year we simply worry about WWIII. Whoops, wrong thread.
Old 16th March 2003, 09:00 AM   #8
Circlotron's Avatar
One of my favourites too. I have just one, brand new in box made by RCA in 1972. Anyway, I once saw a cct that used a pair of 807's running at about 700 volts or so and zero bias and had *all three* grids of each tube strapped together and driven with a transformer (grid current BTW) and it was supposed to get 120 watts at 2% distortion. It was a modulator for an AM transmitter.That's all I can remember now. Never seen that approach used by anyone.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 16th March 2003, 10:54 AM   #9
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Default Re: It takes a worried man...
My three principal worries are
a) Trying to find 8116s/YL1071s at sensible prices
b) The outrageous level of tobacco tax in England
c) Why can't I "get more" smilies??
7N7
Plug them in and light them up
Old 16th March 2003, 11:17 AM   #10
RIP
pedroskova's Avatar
Default Re: Re: RAIN FORREST.
...as in Dubya Dubya III
Harmonic Distortion In Maggies JimOfOakCreek Planars & Exotics 2 20th April 2008 04:04 AM
Why is distortion harmonic? dsavitsk Tubes / Valves 48 12th March 2008 02:49 AM
What effect does a TL have on harmonic distortion? owdi Multi-Way 0 26th April 2006 03:55 PM
second harmonic distortion tenderland Tubes / Valves 5 5th August 2004 11:29 AM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
Page generated in 0.12687 seconds (82.87% PHP - 17.13% MySQL) with 11 queries
