Fostex Meets Pentode I need some NFB
Old 25th June 2008, 01:32 AM   #31
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by Wavebourn
I made pair from ancient Altec Lansing LC EQ.
When i was making my comment, my thots were that that approach might have a chance...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th June 2008, 07:41 PM   #32
alexmoose is offline alexmoose  United States
alexmoose's Avatar
Applying cathode feedback (putting the cathode bypass cap to Speaker terminal in stead of ground) gave me ~7.8 db of NFB, I think I am going to try and reduce that to ~3db with a capacitive voltage divider. However Preliminary listening is disappointing, It sounds Kinda like a bad "Sand" amp, distortion is defiantly characteristic of Negative feedback being present. I am going to try a voltage divider to bring that feedback down, but It looks like Zobel is going to be the answer...
Fostex Meets Pentode I need some NFBHide this!Advertise here!
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 07:29 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 12:03 AM
I need some pictures from DIY AUDIO meets - Can YOU help? SkinnyBoy The Lounge 10 7th September 2003 12:46 PM
