Fostex Meets Pentode I need some NFB
Old 23rd June 2008, 12:23 AM   #21
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by Jeb-D.
The good thing about these type of circuits is that they are all in parallel with the driver, so the speakers can still be driven just fine by a voltage source amp
Do you mean a resistor in series with the driver?
The Devil is not so terrible as his math model is!
Old 23rd June 2008, 12:37 AM   #22
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
The resistors, capacitors and inductors are all in parallel with the driver. Check this article
http://www.passdiy.com/pdf/cs-amps-speakers.pdf
I've used similar circuits to drive a full-rangers using Pentode output stages without NFB. It tames the impedance variation of the driver, but it doesn't have to be flattened completely, which is where the benefits come it.
Old 23rd June 2008, 02:47 AM   #23
Tweeker is offline Tweeker  United States
Into really low impedance loads, 6L6 family makes mostly 2nd harmonic, though lots of it. A differential pair current amp might be interesting.
Be sure your foil hat has a good low impedance ground.
Old 23rd June 2008, 02:53 AM   #24
Wavebourn's Avatar
In such case with a voltage amp (very low output resistance) the single effect of them is increase of power losses.
Nelson means in the article exactly what I said: you may use such an approach with "voltage amplifiers", but R0 how he calls it should be in series with the load.
I've used similar circuits to drive a full-range using Pentode output stages without NFB. It tames the impedance variation of the driver, but you don't have to flatten it completely, which is where the benefits come it.
A 31 - band graphics EQ is your friend.
Old 23rd June 2008, 03:29 AM   #25
Jeb-D.'s Avatar
That is true. At some frequencies there will be an increase in loss, but power dissipation will be more consistent throughout the frequency range.
Sorry I didn't totally understand your statement at the time. Of course the principal can be adapted to "voltage amplifiers", but both frequency response and impulse response(which will differ with source impedance) must be considered. The point of my posts is that a Pentode can be used to drive a pair of full rangers (really well) without NFB. Not that I'm against NFB, many of my designs use it.
I think the "Pentodes have bad sonics" rap is purely from mis-application. A Pentode amp would probably do really well with Magnepan speakers as well. They have a near flat impedance and require a lot of power!
I've never got to play with a good one, but I bet that is true.
Old 23rd June 2008, 06:38 AM   #26
Wavebourn's Avatar
I've never used pentodes without feedback: I believe that both extremes cause most distorted power amplification.
By the way, solid state amps (except probably designed by John Curl) with resistors added in series with speakers sound much better than without them.
Old 24th June 2008, 09:07 AM   #27
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by alexmoose
two identical drivers in series (FE127) with a capacitor in between them to shunt high frequencies to ground, this way, all of the high frequencies goes into the front driver, while the baffle step correcting low frequencies get spit out both drivers.
To get the front driver only to produce highs the cap has to be across the rear driver's terminals... if the cap is in series with both drivers, you are just rolling off the bass.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th June 2008, 09:11 AM   #28
frugal-phile(tm)
planet10's Avatar
If you can find one that doesn't sound disgusting...
dave
Old 24th June 2008, 11:34 PM   #29
alexmoose is offline alexmoose  United States
alexmoose's Avatar
I read the article about Peter Millet's Might Midget because it uses Plate to Grid feedback, and I read something when I notice a line on page 3 that said "An un-bypassed Cathode Resistor is s form of Cathode feedback"
This got me to thinking, what If I apply local feedback by using a Zobel in series with the bypass Cap? is this practical?
Old 25th June 2008, 01:01 AM   #30
Wavebourn's Avatar
I made pair from ancient Altec Lansing LC EQ.
They had initially too many opamps with horrible additional transistor buffers.
Fostex Meets Pentode I need some NFBHide this!Advertise here!
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 08:29 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 06:16 AM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 01:03 AM
I need some pictures from DIY AUDIO meets - Can YOU help? SkinnyBoy The Lounge 10 7th September 2003 01:46 PM
Copyright ©1999-2017 diyAudio
