diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   big doubt: dynakit st35 VS diytube st35clone (http://www.diyaudio.com/forums/tubes-valves/124967-doubt-dynakit-st35-vs-diytube-st35clone.html)
leitmo 17th June 2008 07:01 PM
hello DIYers
this is my first thread and i start with a big doubt: i want to build one of this amps but...which one???
http://www.dynakitparts.com/store/product.aspx?id=1
http://store.triodestore.com/diy35kit.html
dynakit st35 seems to be a reedition of original Dynakits but i don't know if parts will be same quality, it has cover optional
triodestore st35 has forum support and i'm quite sure it was designed by Dynakits creator, it has no cover optional
any suggestion??
if you know any similar tube amp kit in price (400-500$) and specifications (15-25W) let me know
Thanks all of you!!!!!
audiowize 17th June 2008 07:12 PM
The kit from Dynakitparts is a very traditional ST-35 kit, right down to the layout, chassis, etc. I would recommend getting it with the metal film resistors if that is the route you choose.
The kit from Triode Electronics is based of a single stereo board for both channels, integrating a more modern design that takes advantage of some of the different parts that are currently available. Assembly would be a little bit easier on this kit, but it will not have the upgrade options that the stock kit would have.
If it was me, I would get the Dynakitparts kit over the triode kit. Really, it boils down to tube choice for me. I will blatently avoide the 12AX7 whenever I can, and the 12DW7 is not a bad tube at all. Also, the cosmetics of the traditional kit seem preferable to me.
Wolf012558 17th June 2008 08:05 PM
Bob Latino's Dynaco ST-70 kit
leitmo,
Last October I built Bob Latino's Dynaco ST-70 kit. It's a little more money ($625) than the ST-35 kit from either Dynakitparts or Triode but has double the power (35 WPC vs 17.5 WPC) of the ST-35. Bob has been a Dynaco repair person for many years and has been offering his kit now for about the past 2 years. The kit is a totally upgraded offering of the old original ST-70 kit.
The assembly manual is very well written and easy to follow and the sound quality of the amp is far better than the old original ST-70 I still have here. He has a web site where you can read more about the amp at the link below.
http://picasaweb.google.com/arnoldma...ArnoldMatthews
He also has a 60 watt per channel version of the same amp at the link below ..
http://picasaweb.google.com/arnoldma...ST120Amplifier
Charlie
ArtG 17th June 2008 08:32 PM
DIYTUBE-ST35 also offers a semi-kit that features some improvements over the original DYNACO offering, such as individual output tube biasing and separate 12AX7 and 12AU7 tubes rather than the combined 12DW7/7247. Other than those two changes it very closely follows the original circuit, so the sound will be similar, but probably a little better than original with the improved power supply filtering and improved parts quality. I've heard one and judged it to be very good IMHO. This semi-kit arrangement also offers some flexibility, if you wish to make your own "improvements" such as a tube rectifier or a classy chassis!
If you want to look at it, the link is below. As you'll see, they offer considerable support.
http://www.diytube.com/phpBB2/viewforum.php?f=1
leitmo 20th June 2008 02:54 AM
thanks for replies!!!
i think i will go on with dynakitparts, same power but an amazing chassis and cover
I'm not looking for an audiophile amp with best caps or tubes, i only want to hear sweet music while staring at the tubes glowing
thanks averyone!!!
jaymanaa 26th February 2016 10:28 PM
Originally Posted by audiowize (http://www.diyaudio.com/forums/tubes-valves/124967-doubt-dynakit-st35-vs-diytube-st35clone-post1541268.html#post1541268)
Um, isn't the 12DW7 half 12AX7 and half 12AU7? So if you dislike the 12AX7, you must also dislike the 12DW7, wich is more expensive and harder to come by in the Mullard line. I used the DIYTUBE kit that uses a 12AX7 as the first voltage amp, one plate per channel, then a separate and affordable 12AU7 for phase inverting, which is exactly what those tubes were designed to do. I did take the liberty of installing a 10v TX to run the filaments of the 10BQ5 tubes which were cheap way back when I built it. I'm still using the quad of black plate TungSols I put in it 2007, I run them at 35 Ma, and you can just barely start to see the getter receding if you look really close. I use this amp as a test bed for tube rolling, I mean how much better can it be when you ony need one of any give tube to try it out. I've even run 12AT7s up front because like you, I am not a huge AX7 fan. I recommend findind old original OPTs and using a new PT. I've had more offers to buy this amp at meets and such than any other amp I own. The combo I've found is a black plate extra support rods RCA command 12AU7 and a Holland made Bugle Boy 12AX7 in front. YMMV of course.
Resources saved on this page: MySQL 18.75%
