| diyAudio Sponsor | ||
#21 |
They absolutely can use negative feedback. They can also be run without it using much simpler circuits than their solid state equivalents.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#22 | |
That's what I was thinking but then I read
I should have known better than to trust wikipedia blindly without checking references (wikipedia is only a secondary source of information). Thanks for the quick reply. |
#23 |
"Not as much" does not mean "zero." 20dB is a typical number for a conventional push-pull transformer-coupled amp.
#24 |
I see, I misread the "as much part", in my defence english is my second language.
#25 |
In the case of Triodes, local negative feedback from Plate to Grid
is already built-in. They are extremely linear in voltage output, and fairly linear in current output, all without much help. Break that internal feedback loop, and you have a Tetrode. Same goes for Pentodes, Heptodes whatever.... Tetrodes are very solid-statish in behavior. Not terribly linear without help from an UltraLinear tap on the transformer. Or external plate to grid feedback scheme such as O.H.Schade They handle more power, but if you want to retain linearity (as-if a Triode) there will be a feedback somewhere... The same schemes can be applied to sand but is rarely done correctly. Search the Solid board for "FETron", as I think that is one of the best. And may help you to grasp what a triode really does inside to make it so linear. All without the help of a dozen external parts to fake it. In the case of P-Triode, faking it might be worth the effort. |
| Total newbie post - trying to replace ext. PS on vintage Mark Levinson ML-1 preamp | yamezxx | Power Supplies | 3 | 26th August 2009 04:29 PM |
| Amp design Newbie help anyone? | matt09 | Chip Amps | 11 | 7th August 2006 10:27 PM |
| Newbie design | mikec | Multi-Way | 7 | 5th April 2004 02:03 AM |
| A guiding Post for helping any Newbie to start.. | deepanger | Solid State | 0 | 11th December 2002 10:01 PM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
| Page generated in 0.08039 seconds (74.29% PHP - 25.71% MySQL) with 11 queries |
