I'm looking for some help in building a PP amp using the 6CK4. If someone has any hints or info, I would certainly appreciate some guidance what kind of load line, etc.
Tks, Jack T. |
#2 |
Hmm...neat tube , I want some!!
Sorta like 6W6 I guess... anywho... For class A1: maybe 200V supply, 50mA bias (-20V grid, 400 ohms per tube if cathode bias) = 10W dissipation (I'm sure you could push 15W Pd, vertical deflection is tough so it's going to be a hearty tube). Loadline. Go up to the zero-bias curve and choose a point.. approx. double current (i.e. 100mA) is typical. That seems a little shallow so I'll say 125mA, which happens at 100V. The flipside of the point occurs at -40V, twice the bias voltage, about 5mA/255V. Thus Imax and Imin are 124 and 5mA respectively; Io (operating) is 50mA; Vmax is 257, Vo is 200, and Vmin is 100V. The slope of the loadline is the resistance, (Vmax-Vmin)/(Imax-Imin), or about 1.3k. You can also calculate distortion, based on: Code:
Imax + Imin
------------- - Io
2
2nd H % = -------------------- * 100
Imax - Imin
) to:Code:
2nd H % = 50(Imax^2 - Imin^2) + 100Io(Imin - Imax) )Anyway. That comes to 12%, but I just remembered that 2nd H is canceled in PP amps so you can ignore it Have fun. Wonder how many responses popped in while I typed this...(when I started there were none )...Tim |
#3 |
Forgot the graph I prepared..
The loadline shown is SE. For PP, each tube needs to see that - so 1.3k per half (either side of the CT). So the anode-to-anode load must be four times, or 5.2k (you needn't be so exact, a 4 or 6k would work about the same ).Now, this is where I keep forgetting things... Do the tubes act in series, hence a-a = 4*single Rl? Or do they act in parallel, giving a-a nearer 1x? Or somewhere inbetween, say one tube is half cutoff (half Gm or Rp, take your pick) and the load is suddenly on a single tube! Tim |
#4 |
Scroll down this page for one idea.
http://hollowstate.netfirms.com/DIY_files/proto.htm here is another http://tinpan.fortunecity.com/saints...er/6ck4-pp.gif http://tinpan.fortunecity.com/saints...mer/index.html Something to start with anyway. Cheers Craig Ryder
Ryder Any fool can ask more questions than seven sages can answer. |
#5 |
I don't recommend the second one.. 100uF on a 5U4 is liable to pop it, hearty though the tube is!
That guy was probably going from his junk pile, but if you must do it like that, use a lower voltage transformer or choke input.Tim |
#6 |
So many with so much information, so quickly. Do you guys have lives? What more could I ask for? Thanks so very much. I'll put pencil to tongue and go from there!
Tks a mil, Jack T. |
#7 | |
#8 | |
frugal-phile(tm)
-- and there seemed to be perfectly valid arguments for both cases -- over my head at the moment. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 | |
diyAudio Senior Member
Cheers, /This may be an idea for the "Policies thread"...oh well we'll see ...
Frank |
#10 | |
diyAudio Moderator Emeritus
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| 6ck4 pp amp | Sheldon | Tubes / Valves | 93 | 29th December 2005 06:25 PM |
