diyAudio Sponsor
Old 13th June 2008, 11:04 PM   #1
TubeHead Johnny's Avatar
Default What's a good way to clean tubes w/o taking off the labeling?
Cleaning fingerprints (and other dirt) using Windex will undoubtedly take off the lettering of some of our precious tubes. (I found out the hard way) What do you guys use? I know I should use a glove when handling, but sometimes I forget or it's inconvenient. Any ideas?
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz
Old 14th June 2008, 03:36 PM   #2
Anybody? There has to be something out there.
Old 14th June 2008, 04:04 PM   #3
I've had a lot of tubes where rubbing of any sort will remove the white lettering. I don't worry so much about it, but just try to make sure I know what the tube is!
I used to be an audiophool like you but then I took an arrow to the knee.
Old 15th June 2008, 08:02 AM   #4
If they are really filthy from sitting in a shed for 50 years I just use warm water, maybe with a bit of soap. Sometimes the printing comes off, but I've not found a way around that.
If they are not so dirty I don't worry about it.
Old 15th June 2008, 11:03 AM   #5
Tweeker is offline Tweeker  United States
A cotton swab can at least clean the parts that arent lettered.
Be sure your foil hat has a good low impedance ground.
Old 15th June 2008, 05:37 PM   #6
kevinkr's Avatar
That's what I do too, usually with 90% rubbing alcohol. (Or methylated spirits in the UK IIRC..)
www.kta-hifi.net
Old 15th June 2008, 09:46 PM   #7
dnsey is offline dnsey  United Kingdom
I've long wondered why the 'consumer' numbers are printed using such an ephemeral process, especially as house numbers are often robustly engraved on the same tubes.
Does anyone know?
Old 15th June 2008, 11:55 PM   #8
AVWERK is offline AVWERK  United States
Funny this comes up as I just pulled a box down of 12xx's containing real telefunkens, Amperexs, and some gold Aero's.
I had wrapped them in 1/4 foam that rotted over them. just grreeaatt
Whats left is a sticky goo all over them.
I used hot water with the spray wand and some 409 cleaner.
I got most of it off with a light cloth to finish up. Saved about 90% of the lettering
Hope this works for you
David
Old 16th June 2008, 12:04 AM   #9
Wikkid is offline Wikkid  United States
'fraid there isn't really much of a way to do it, other than
just (carefully) cleaning all the areas around the writing...
Old 16th June 2008, 12:12 AM   #10
cerrem is offline cerrem  United States
I use fine steel wool to clean glass...I make sure to avoid the letters...
Chris
Fender always taking care of tubes.... Cassiel Tubes / Valves 2 28th May 2009 03:30 PM
Labeling faceplates the TT way JesseG Everything Else 5 2nd February 2007 12:20 AM
Canon EOS300 - good for taking pictures of hifi. annex666 Swap Meet 3 24th April 2004 12:00 PM
Labeling/Marking Enclosures ? sam9 Parts 3 11th January 2003 07:51 PM
Page generated in 0.09890 seconds (77.61% PHP - 22.39% MySQL) with 10 queries
