diyAudio Sponsor
Old 13th June 2008, 05:14 AM   #1
gary h is offline gary h  United States
Default pin count question
Hi all,
forgive my ignorance, but what is the difference between octal and 9-pin tube types? I'm not looking for a discussion on the sonic merits of each but just the simple facts.
Thanks,
gary
Old 13th June 2008, 05:27 AM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
What kind of difference? Octals are physically larger and more rugged, easier to solder up, the pins connect better with the sockets, they are better for heat dissipation and can generally handle higher voltages and wattages.
9-pins are compact, look cooler and generally are more modern in their design - compare an EL84 with a 6V6 for example- the EL84 is a better valve.
In my experience there are too many other variables to say for example that an octal preamp will sound better than a 9-pin preamp. The right valve in a well designed circuit will sound good.
Old 13th June 2008, 05:40 AM   #3
Tweeker is offline Tweeker  United States
With small signal stuff, some noval tubes designs focus on gain at perhaps the sacrifice of other qualities as feedback saw more use than when the octals were developed.
Noval tubes have lower lead inductance than octal tubes. More an issue at RF.
Higher gm types (and just more types in general) are more available in the noval format.
Be sure your foil hat has a good low impedance ground.
Old 13th June 2008, 05:40 AM   #4
That's what I was looking for, thanks.
What does that one extra/less pin account for?
gary
Old 13th June 2008, 05:49 AM   #5
The extra pin does not necessarily account or attach (or is parallel attachment) to anything.
Sometimes its used connected to a screen (pin to ground) for an electrostatic shield between two tube sections, or with say a triode/pentode compound tube you might just need all those pins, or more (11 pin etc.)
Old 13th June 2008, 06:21 AM   #6
Thanks for the replies.
gary
Old 13th June 2008, 07:03 AM   #7
Miles Prower's Avatar
That extra pin allows for such things as being able to make triode/pentode types like the 6KE8, to center tap heaters for 6.3V/12.6V operation, to place an electrostatic shield between sections of a dual triode.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 16th June 2008, 10:07 PM   #8
Merlinb is offline Merlinb  United Kingdom
Since there was pressure on manafacturers to miniaturise, it was a natural step to go from octal to the smaller noval, and then 7-pin, and even smaller in the latter half of the 20th century with the sub-miniature valves.
Having more pins allows more valves to be fitted into the same bottle. In Britian, radios were taxed based on how many bottles were inside, so miniaturisation was important here, while America continued to use mainly octals (they like things bigger there, so I hear!)
2006 Iowa DIY Speaker Event Nose Count! jholtz Multi-Way 0 14th October 2006 04:18 PM
3db increase by doubling driver count Bazukaz Multi-Way 53 17th July 2006 09:30 AM
Eliminate Member Rankings And Post Count kelticwizard Everything Else 163 11th January 2003 03:17 AM
Page generated in 0.09721 seconds (74.20% PHP - 25.80% MySQL) with 10 queries
