| diyAudio Sponsor | ||
Hi There
I just finished 1 channell of my 12 Volt pre amp for my Kart Trailer sound system. I have 2 12el6's configured in srpp run by a battery and by jingos it doesnt sound too bad at all. I have 1k on the cathode to anode connection and 1k on the lower tubes cathode. Current draw is 350 mA per side. I had read that space charge tubes "like" a bit of current. Funnily enough the amp still puts out signal with only the heaters turned on and the volume increases once i kick the anode supply in. Output is a little low so i might halve the value of the cathode resistors to 500 Ohm instead of 1k. AT this point i have .15V on the cathode resistor to ground which equates to .00015mA. The top tube b+ is 12V whilst the lower is 9V. I figure it should have 1/2 b+ on it so i need to mess with the resistor value All in All a very satisfying experiment. Thanks Nick
"Better to say nothing and keep them guessing than to speak and remove all doubt." |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 05:52 AM |
| 12el6 | duderduderini | Tubes / Valves | 3 | 7th June 2008 06:31 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 10:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 08:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 11:13 PM |
| Page generated in 0.06638 seconds (68.61% PHP - 31.39% MySQL) with 10 queries |
