| diyAudio Sponsor | ||
#11 |
работник
Tom, Tweeker - THANKS. I have learnt something, and know now that spalling is right.
Tom, is the spalling effect the only reason why (for instance) EL84 is rated for 300V in dc service, but EL86 is rated for 250V? Both have Vao = 550V. Are there other limits on continuous anode voltage? |
#12 | |
Yes, voltage isolation- leakage, arcs.
The EL86/6CW5 was intended for higher current at lower voltage than the EL84. It even saw use in some OTL apps with 800 ohm speakers.
Be sure your foil hat has a good low impedance ground. |
#13 | |
| small-signal (small-power) fast switching complementary transistors | Lola Luna | Solid State | 3 | 8th April 2010 07:51 PM |
| Small signal pentode - zener screen regulation - why not ?? | Shoog | Tubes / Valves | 3 | 30th July 2008 06:24 AM |
| Looking for a small yet powerful pentode / dual triode? | space-cake | Tubes / Valves | 15 | 19th September 2007 05:53 PM |
| A small no-fuss pentode/pentode SE amp | Tubes4e4 | Tubes / Valves | 13 | 1st January 2006 05:16 AM |
| Page generated in 0.07560 seconds (71.28% PHP - 28.72% MySQL) with 10 queries |
