diyAudio Sponsor
Old 12th June 2008, 04:12 AM   #11
Default 2 x 12v globes
One other idea I have seen BUT not tried myself, however the guy who did it claimed it worked "like a treat".
Put a 24V globe (or 2 x 12v in series etc) in series with the mains input. It doesn't relly matter if its in the active or neutral side. Choose globe wattage such that globe current is matched well to ioperating current.
Ian
Old 13th June 2008, 12:20 PM   #12
johnm is offline johnm  United Kingdom
johnm's Avatar
After thinking about this I decided if something is worth doing it's worth doing right, so I've ordered a custom made transformer for this project to solve all the above problems.
Thanks for all your replies
- John
Old 13th June 2008, 01:12 PM   #13
Tweeker is offline Tweeker  United States
Hi John,
and then using a meter connect the probs to the 300V secondary, and CT to measure the secondary voltage?
If its full wave rectified, one can use a zener to CT to drop HT voltage. Doesnt fix the heaters, but here one could use resistance without performance issue.
Be sure your foil hat has a good low impedance ground.
Old 13th June 2008, 07:26 PM   #14
TubeHead Johnny's Avatar
I want to drop the level of mains voltage supplied to a pre-amp from our measured 247V 50Hz AC wall outlet, to 220V, which the pre-amp is spec'd for.
Why don't you just get a power conditioner with voltage regulation (AVR)? Using resistors to lower AC line voltage is not a good idea (believe me, I tried it). All that AC is going to be transfered to heat...enough to heat your house! I know Tripp Lite has a few inexpensive 120V models at PartsExpress, but I'm sure
they have a 220V model as well.
"No man really becomes a fool until he stops asking questions" - Charles Proteus Steinmetz
Old 13th June 2008, 07:41 PM   #15
johnm's Avatar
Thanks for your suggestions, but I've gone ahead with ordering a custom-wound mains transformer, so problems solved
Thanks,
- John
Lower voltage LM386? DonFlamenco Chip Amps 1 6th September 2006 10:56 PM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
resistors of a lower power rating 9am53 Tubes / Valves 2 15th May 2005 04:06 AM
Zen with lower voltage? DorcyDuck Pass Labs 9 20th April 2004 05:02 PM
How to lower supply voltage avenger Chip Amps 18 24th November 2003 07:20 AM
Page generated in 0.07162 seconds (75.56% PHP - 24.44% MySQL) with 10 queries
