| diyAudio Sponsor | ||
#11 | |
I serviced/repaired a Music Angel Amplifier, but, having said that, if by 'pulsing', you mean oscillating, surely no valve in an amplifier should oscillate. This could indicate poor grounding, faulty capacitors, or other problems. Having just downloaded the circuit diagrams of the XD500mkIII, I'm a little puzzled to see that 28mV @ 105kHz is present at the speaker terminals-almost 6 times the level at 121hz. Seems wrong to me! |
#12 | |
#13 | |
I've asked to guy for a film of the amplifier when up and running. What is the problem when looking at the circuit diagrams? Is it a bad amplifier? |
#14 |
YouTube - M2U00065
That's the amplifier up and running. What do you think? I didn't see any difference between the two, to be honest. Do you? Edit: A friend of mine said it looked like a "Magic Eye". After googling a little it seems like it's just cosmetic, built into the tubes. If i can't stand with it i just guess i have to change tubes. But if one pulsates slower than the other, is it the "Magic Eye's" fault or something else? :O Edit 2: One think i came to think of. Maybe it depends on the music being played. If there's more stuff going on in the left channel it obviously needs a little more power. And then the left "eye" blinks more than the right one, and vice versa. Or is it a faulty tube or even the amp? Maybe it could be the amp sending the signal slower/weaker to one of the channels? Last edited by Rullknufs; 11th January 2011 at 05:09 PM. |
#15 |
The amp is a reasonably good one.
The price of around $700 may however seem a bit high, especially if some tubes are close to burning out. You can buy a new MA with KT88 for $600 including shipping (but excl. your country's VAT). The general opinion is that this is a better amp, especially if you roll some of the small signal tubes. Svein |
#16 | |
So, if we say my amp is 3000 and then i pay 1000 and 450 for fuel. That's around 650$ If i buy somthing from outside of EU i have to pay the 25% swedish Moms. And then there's the toll fee and such... Would end up at around 1000$ or so probably. |
#17 |
I stand corrected, Rullknufs. Didn't realise that you were speaking of the Magic Eye (or
'Cat's Eyes' as the schematic calls them) As far as I can tell from the You Tube video, they are behaving as I would expect such indicators to perform-i.e. responding to the variations in sound level in the music, which is of course in stereo. If a sine or square wave signal of the same amplitude was fed into each channel, then the indicated level, subject to the usual component tolerances, would be the same for both channels, and the display from the 'eyes' would be steady. As Svein_B says though, the price still seems a bit high, if a new KT88 equipped MA can be had for $600 +VAT(in the U.K. that would make it $720, or approx. 4930 Swedish Kroner- with 25% tax in Sweden, though, the total price would be $750. At any rate you'll have to be the judge of which is the better buy |
#18 |
Well. If i buy the KT88 stuff (can you please link to it?) i guess i will have to ship it from outside Sweden. I don't think my parents would like that at all since they're suspicious to everything.
But if you link it it will take a look at it. |
#19 |
I don't have a link to the M.A. XD-SE (KT88) amplifier. The circuit is essentially similar to the EL84 version. They are probably available from China or Hong Kong on E Bay. As noted in my earlier reply
I was simply quoting from Svein_B's post. I do have some printed information somewhere about the amplifier, most, if not all of which, came from other posts on this forum 3 or 4 years ago. From memory, a similar circuit to the EL84 version(based on the classic Williamson design) is used, with either triode or Ultra Linear o/p stage configuration selectable via a front panel switch. Last edited by OXAUDIO; 12th January 2011 at 08:47 PM. |
| My Experience with "Music Angel" EL34 PP | gingertube | Tubes / Valves | 48 | 12th January 2011 07:58 PM |
| music angel 845 SET | PeterParsons | Tubes / Valves | 6 | 21st December 2009 05:52 PM |
| Music Angel EL34 XDSE | knagy | Tubes / Valves | 1 | 7th October 2007 11:53 PM |
| help me i need schematic of Music angel PP el34 | lilepa | Tubes / Valves | 1 | 8th May 2007 06:09 PM |
| Music Angel EL34 | SimonPearse | Tubes / Valves | 0 | 27th February 2006 08:27 PM |
| Page generated in 0.11685 seconds (85.79% PHP - 14.21% MySQL) with 11 queries |
