diyAudio Sponsor
Old 9th June 2008, 07:57 PM   #21
Pyre is offline Pyre  Canada
Pyre's Avatar
Send a message via MSN to Pyre
They must have it wrong or something.
That is a pretty interesting tube. have you ever used them in anything? How did it sound if so.
12 pin socket, is that the same as the old plug in relays used?
Old 9th June 2008, 08:02 PM   #22
Send a message via AIM to audiowize
I have used:
6FM7
6FY7
6FJ7
I plan to implement a 6U10 as a single tube Mullard phase splitter in an upcoming project. These are some of the last American made tubes, and IMO are quite excellent, especially at the price. The only problem with them is trying to get people not to throw them in the trash.
-Paul
Old 10th June 2008, 03:59 AM   #23
Also, 6C10's and 6D10's can be a little expensive here and there, but I bet you can find some pretty cheap pretty easily.
6C10s are nearing extinction. They are used in some older guitar amps (Ampegs IIRC) and they have been pretty well used up.
The 6AC10 is a much more common and available cheap triple triode, but it's not 3 12AX7 equivalents.
Old 14th June 2008, 10:02 AM   #24
cogsncogs's Avatar
Hello Pyre
The 6AV6 has two diodes, pins 5 and 6 with pin 2 serving as a common cathode, shared with the triode section. Ground pins 5 and 6.
AES may have some 12AV6's cheap and you'll be all 12.6V filament-wise!
I've never been a fan of these tubes but they should be ok in the CF position.
Wayne
I'm back!
Old 16th June 2008, 10:02 PM   #25
Merlinb is offline Merlinb  United Kingdom
Default Re: Tube equal to one section of a 12AX7?
Originally posted by Pyre
Is there a 9 pin tube that is equal or very close to one section of a 12AX7?
The Russian 6N2P is basically the same as a 12AX7, except for a different pin arrangement (6.3V heater only). Obviously they have two triodes inside, but they are very, very cheap!
About an hybrid LM3886 amp using 12AX7 tube gaetan8888 Chip Amps 21 3rd November 2009 08:08 AM
ECC83/12AX7 Tube test query waam68 Tubes / Valves 8 8th November 2007 08:52 PM
Help! first tube pre-amp with 12ax7 zafira1981 Tubes / Valves 2 8th December 2006 10:37 PM
Using a 6SL7 in a tube overdrive pedal instead of 12AX7? G Tubes / Valves 5 21st March 2005 12:34 PM
Counterpoint SA-220 Tube section advice needed KBK Tubes / Valves 31 24th January 2005 01:42 AM
Page generated in 0.10104 seconds (75.39% PHP - 24.61% MySQL) with 10 queries
