diyAudio Sponsor
Old 9th June 2008, 05:25 PM   #11
Ahh. That explains it.
Thanks SY.
Old 9th June 2008, 05:28 PM   #12
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
I thought the 6C4/EC90 was half a 12AX7. Not going to be much cheaper than just using a 12AX7 though...
AJ
Old 9th June 2008, 05:30 PM   #13
SY's Avatar
Originally posted by oshifis
~ 6AQ4 (EC91)
Similar mu, but otherwise quite different. Great for RIAA stages when used appropriately.
Stormrider, no, I don't think they're the same.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 9th June 2008, 05:47 PM   #14
kevinkr's Avatar
Sy's right, for audio applications the EC90/6C4 single triode is equivalent to a single section of a 12AU7. (Besides audio applications the 6C4 was commonly used in HF/VHF oscillators which was not a recommended use for the 12AU7, implying some other slight differences in internal construction.)
For convenience sake I would just stick to 12AX7A and wire the added sockets in each PAM so that the opposite triode is used, that way at tube replacement time you can just swap and save on purchasing two new tubes.
www.kta-hifi.net
Old 9th June 2008, 06:32 PM   #15
dsavitsk's Avatar
Originally posted by SY
Lower cost? I think it will be more expensive. You're limited to NOS and need twice as many.
High quality 12AX7s are pretty inexpensive. JJ is under $10 brand new.
NOS 6AV6 is on sale at AES for $2.48 right now. They are $3 at RES, and $3 at the tube center.
http://www.ecpaudio.com
Old 9th June 2008, 06:32 PM   #16
Send a message via AIM to audiowize
The 6D10 and 6C10 are compactrons with three triodes per tube, each equivalent to a 12AX7. Compactron sockets are also available/cheap now.
-Paul
Old 9th June 2008, 06:41 PM   #17
Pyre is offline Pyre  Canada
Pyre's Avatar
Send a message via MSN to Pyre
Wow thanks! Now thats a reasonable price. I am going to go check them out.
-Paul
Interesting. The whole thing could be done in one tube. Do you think there would be any problem with doing all 3 sections in one tube?
Old 9th June 2008, 06:45 PM   #18
Interesting. The whole thing could be done in one tube. Do you think there would be any problem with doing all 3 sections in one tube? [/B][/QUOTE]
Likely not. You need 3 halves per channel, so you can isolate each channel into one tube. If you have some direct coupling/cathode followers and you need two different heater supplies, that's the only issue I can find. Also, 6C10's and 6D10's can be a little expensive here and there, but I bet you can find some pretty cheap pretty easily.
Old 9th June 2008, 07:31 PM   #19
Pyre's Avatar
-Paul
AES does not have any 6D10's but they have 6C10's but says they are a delay relay.
6C10 - DELAY-RELAY, AMPERITE
• 6.3 volt heater
• Normally closed contacts
• 10 second delay
• Standard 8 pin octal base
Six 6AV6's with sockets ring in at just over 22 bucks. Thats well within my price range SOLD
Old 9th June 2008, 07:34 PM   #20
• 6.3 volt heater
• 10 second delay
Here's the datasheet:
http://www.mif.pg.gda.pl/homepages/f...127/6/6C10.pdf
About an hybrid LM3886 amp using 12AX7 tube gaetan8888 Chip Amps 21 3rd November 2009 08:08 AM
ECC83/12AX7 Tube test query waam68 Tubes / Valves 8 8th November 2007 08:52 PM
Help! first tube pre-amp with 12ax7 zafira1981 Tubes / Valves 2 8th December 2006 10:37 PM
Using a 6SL7 in a tube overdrive pedal instead of 12AX7? G Tubes / Valves 5 21st March 2005 12:34 PM
Counterpoint SA-220 Tube section advice needed KBK Tubes / Valves 31 24th January 2005 01:42 AM
Page generated in 0.11351 seconds (80.53% PHP - 19.47% MySQL) with 10 queries
