| diyAudio Sponsor | ||
diyAudio Moderator Emeritus
If not using transformer coupling, a direct-coupled CF or SF driver for a PP output stage would seem to offer a number of advantages. It can be used to prevent blocking distortion of pentodes, to supply sufficient drive current to overcome miller capacitance of triodes, or to serve as a low impedance source to drive Class AB2.
Seems like a good idea to use this type of driver in every PP design, but is there any downside to doing this? |
#2 |
Take a look at the McIntosh amp schematics...
Chris |
#3 |
hey-Hey!!!,
Whatinthehell is, 'blocking distortion of pentodes'? On the rest, the CF/SF will add another stage. If it isn't enclosed in a FB loop, there is no risk. What it might sound like is going to depend on the implementation. cheers, Douglas
the Tnuctipun will return |
#4 | |
This kind of distortion can be counter-acted, to some extent, by using a high value grid stopper on the OP tube or it can be completely avoided by using DC coupling (i.e. no coupling cap at all). |
#5 |
I wasn't aware of the recovery time difference. As far as I know, they're pretty much the same- it's the RC time constant which determines recovery time.
OK, you know the advantages of a follower (I think source followers are even better in that application, but I'd probably be disinvited from the European Triode Festival this year for saying that). The feedback question Douglas raised is probably not an issue- follower bandwidths are ridiculously good. One more advantage is the ability to drive appropriate tubes in AB2, which is good for another dB or two of power. Disadvantage is parts count and heat. For a fixed-bias triode output stage, I'd use a follower driver whenever possible. For a fixed-bias pentode that won't be driven AB2, I'd probably just use a big grid stopper instead.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#6 |
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#7 |
#8 |
#9 | |
And two more: Vixen Le Renard |
#10 |
Ray,
I thoroughly RECOMMEND a Source Follower drive of output tube grids. Advantages are, as you state, freedom from blocking distortion. It also allows use of low Rg1 resistor values which helps with bias stability too. Waveborn has obviously been reading Allen Wright. He is showing a MOSFET version of Allens SLCF. With triodes it is good to current source load the cathode follower (Constant Current mode operation) and Bootstrap the anode voltage (Constant Voltage mode operation). With a MOSFET Source Follower I might consider the current source load (although I'm using simple resitive load with good results) but as long as you keep minimum Vgd to say +25V with maximum signal swing, then the bootstrap is totally un-necessary. If you want to go the "No Sand" route, then use a pentode cathode follower with the screen bootstrapped to the output - with or without a current source load. Cheers, Ian |
| Best emitter / source / cathode follower topology | borges | Analog Line Level | 20 | 2nd November 2007 12:57 PM |
| Question about biasing heater above cathode in a direct coupled circuit. | G | Tubes / Valves | 1 | 26th May 2007 12:42 PM |
| Schematic please? SRPP with current source cathode follower | riotubes | Tubes / Valves | 0 | 7th January 2007 06:18 PM |
| use of 6dj8 as driver on a direct coupled 2a3 se amp | camotecue | Tubes / Valves | 2 | 21st September 2004 02:16 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 07:47 PM |
| Page generated in 0.10870 seconds (79.78% PHP - 20.22% MySQL) with 11 queries |
