| diyAudio Sponsor | ||
#81 | |
With pentodes, it is g1 to g2 capacitance that matters. Hold g2 'still' and g1 sees very little capacitance. Clearly when g2 has signal it will have multiplied the C just as in the triode/miller effect. Higher tap %-age and there is more effective capacitance seen by g1. cheers, Douglas
the Tnuctipun will return |
#82 | |
Neutralize UL screens to opposing grids. Would it work? |
#83 |
Assume beam power, where the supressor grid is virtual.
#84 |
Hi Ken,
Probably working OK, but I don't see any point in the neutralizing to the screen grids. The plate still has to drive the same capacitance either way, either the UL tap point does it or the Neut. cap. from plate does the driving. From the UL tap it even gets some trashformer ratio to help out. Don
Ohms Law V = I R |
| Best emitter / source / cathode follower topology | borges | Analog Line Level | 20 | 2nd November 2007 12:57 PM |
| Question about biasing heater above cathode in a direct coupled circuit. | G | Tubes / Valves | 1 | 26th May 2007 12:42 PM |
| Schematic please? SRPP with current source cathode follower | riotubes | Tubes / Valves | 0 | 7th January 2007 06:18 PM |
| use of 6dj8 as driver on a direct coupled 2a3 se amp | camotecue | Tubes / Valves | 2 | 21st September 2004 02:16 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 07:47 PM |
| Page generated in 0.07399 seconds (69.77% PHP - 30.23% MySQL) with 11 queries |
