Like this?
The topology looks correct, but the 1st filter cap. is too big. Use a 4.7 μF. part. An even smaller value initially may be a good idea. If the rail is too "short" under load, add a little capacitance to the 1st position.
Do you think the 600VCT transformer is the right size to get about 350 VDC, 55 mA per tube (110 mA total)?
By starting with a smallish 1st filter cap., you should be able to tweak the rail voltage exactly.
Hmm... I've unleashed my Google-fu and turned up this article:
http://archive.ampage.org/threads/1...te_of_a_6V6_using_a_6X5_rectifier_tube-1.html
In a nutshell, he's got an amp with a 325-0-325 PT, a single 6X5, and a 51 mA load. He's seeing about 370 volts at the plate, and running about 18 watts dissipation. I think that might be where I'd like to go, and I have to wonder if I'd be happier with a 650VCT PT instead of the 600VCT. I'd hate to build the thing and find out I made the wrong choice.
I guess a lot depends on the power transformer's own source resistance. I don't really know what it is for the Antek toroids, but I've got to expect it's pretty low.
I wonder about the heater cathode limit in the circuit above... if the voltage divides equally (not a given...), there will be 300V AC from each 6X56 cathode to heater. Connecting the cathodes together in the "conventional" connection (plates to ends of HV, CT as negative) will put both cathodes at the same voltage, and there won't be any voltage to the floating heater winding. Would probably be OK with damper diodes, but the insulation in 6X5s is not that good.
A quick sim in PSUD says that the 300V transformer will give about 330VDC - close enough, I think. But 325V might be closer to what you wnat...
Tom Bavis said:I wonder about the heater cathode limit in the circuit above...
Good point. I'll look more closely.
How do you get PSUD to properly simulate the voltage drop when using a pair of 6X5?
Tom Bavis said:...in the circuit above... there will be 300V AC from each 6X56 cathode to heater. Connecting the cathodes together in the "conventional" connection (plates to ends of HV, CT as negative) will put both cathodes at the same voltage, and there won't be any voltage to the floating heater winding.
In the suggested circuit, you'll have 300 VAC H-K, because you're applying 300 VAC to the cathode? And with the "normal" method the H-K eventually ends up at zero volts because the cathodes are at DC and the heater winding floats up to meet it?
Tom,
I don't think there will be a problem with 6X5 heater to cathode insulation breakdown. Look at the data sheet. The design center limit is 450 VDC.
Questions about the Simple SE board: What's the biggest (diameter) capacitor that can fit at C1 and C2?
C1 can go as big as 22.5 mm the hole spacing is 10 mm. C2 can go to 35 mm, with a 10 mm hole spacing.
Could I use these Mouser parts? They seem kinda expensive, though.
They claim a low impedance, which is a good thing, maybe that is why they are expensive. DigiKey lists a 150 uF 450 volt Panasonic for $4.32 each. P13913-ND
They will fit the board, but the 6X5 doesn't like much over 5 uF for the input cap. I have experimented with the 6X5 since I have a few hundred of them. A 47uF input cap, and a transformer with a low winding resistance (like the Antek) WILL lead to a fireworks display inside the tube. The 6X5 has a higher voltage drop than the typical 5AR4. If you want to use the circuit that you show use a small (4.7 uF 450 volt) leaded capacitor, for C1 and a big (150 uF 450 volt) cap for C2.
450 volt capacitors often show up on the surplus market cheap. Now that I have acquired 25 of these I will let everybody in on it. They work in a Simple SE like you are planning, don't try to use them with the big transformers, they will spill their guts. Keep them under 400 to 420 volts. It is the same as the DigiKey part.
http://www.allelectronics.com/make-a-store/item/EC-1450/150-UF-450-V-SNAP-IN-CAPICITOR/-/1.html
I will hook my Hammond 272JX up tomorrow and see what I get. It is a 600VCT transformer, but these are Hammond volts, which are about 650 to 700 real volts. I get 390 volts of B+ in a Tubelab SE using thie transformer. All of the Anteks that I have here are much bigger 4T360 and 4T400, or smaller 1T200 than what you need.
tubelab.com said:...but the 6X5 doesn't like much over 5 uF for the input cap. I have experimented with the 6X5 since I have a few hundred of them. A 47uF input cap, and a transformer with a low winding resistance (like the Antek) WILL lead to a fireworks display inside the tube.
Thanks for the informative and helpful reply. It's got me wondering if I'd be happier in the long run if I just give up on the 6X5 idea and go with the 5AR4. I've already got the 6X5 for "free", but I'm sure I've got an extra 5AR4 laying around somewhere too.
Of course, the 5AR4 is going to need a 5 volt winding from somewhere...
Eli Duttman said:Tom,
Agreed... it's rated +/-450V ... but which is better... 300 or more VAC heater - to - cathode... or essentially zero? LOTS of '30s-'40s Zenith power transformers died from H-K shorted 6X5s - ask any old-time radio repairman!
I just simulated it with 55 mA - half the load. Transformer drop will be double with 110 mA, but it will be small in any case. Make sure your input cap is good for 150 mA or so ripple current - not all small caps will be. You can get the ripple current from PSUD, but a first approximation is same as DC load current.
Don't have much time, just skimming this thread while taking a dinner break from a university assignment...
I have ordered some custom made power transformers from Edcor 2x120 volt primary, 330-0-330v 200mA, 6.3v 5A, 5v 3A secondary for use with 6L6 etc. As the design work has been paid for by me, these transformers should now be on their database and no design fee for custom order. I have not received them yet, so cannot comment on their build quality. Have been happy with the quality of their output transformers though. Oh, price quoted was $63.51
Hope this helps.
Chris
Hope this helps.
Chris
tubelab.com said:I will hook my Hammond 272JX up tomorrow and see what I get. It is a 600VCT transformer, but these are Hammond volts, which are about 650 to 700 real volts. I get 390 volts of B+ in a Tubelab SE using thie transformer.
I've got a mystery transformer running in a PP EL84 amp. Total load is about 140 mA, and the transformer measures about 330-0-330 with no load. B+ on this amp ended up around 400~410 VDC, depending on line voltage (which tends to run high at my house). The power supply is solid state rectified, with a CRC filter (110 uF, 50 ohm, 110 uF0.
I'm thinking even the 272JX is going to be too hot for 6L6GA. I'll probably need to go with something like the 270HX.
That would be my choice since I have toasted a few 6X5's and I am still using the same 5AR4 that I started with about 6 years ago. I decided that the 6X5 just isn't really suited for power amp use except for maybe a 6V6 amp. It does impart a unique sound to a 6V6 guitar amp.
I dug up a pair of golden oldie 6L6G's. Not matched, not even the same brand, but they work. I tried 3 different power transformers. All tests were done in triode mode with a 5K ohm OPT since thats what I had hooked up to the amp. You could get about 20% more power with a 3K ohm OPT, and about 50 to 70% more in UL mode. The choke is a Triad C-14X with a DC resistance of 150 ohms. I stuffed it inside the shell of an old power transformer. The Simple SE board is assembled as per the parts list including 560 ohm cathode resistors.
First the 272JX. The 300 - 0 - 300 volt transformer makes 325 volts AC here. The B+ before the choke is 385 volts, and 365 volts after the choke with a total current of 133 mA. The plate voltage is 360 volts. The cathode voltages are 26.7 volts and 27.0 volts, so the tube itself sees 333 volts. Tube current is 48 mA which works out to 16 watts plate and screen dissipation. Power output at 5% distortion is 3.1 watts. The sound is clean, and sounds similar to other 6L6 type amps that I have built, but not quite as loud or dynamic.
I don't have a 270HX, but I do have a 270FX, so I hooked it up. The 275 - 0 - 275 volt transformer makes 301 volts AC here. The B+ before the choke is 345 volts and 326 volts after the choke with a total current of 124 mA. The plate voltage is 322 volts. The cathode voltages are 24.4 volts and 24.2 volts, so the tube itself sees 298 volts. Tube current is 43 mA which works out to 12.7 watts plate and screen dissipation. Power output at 5% distortion is 2.6 watts. The sound is clean, but the bass is a bit weaker than before.
I have some Allied 6K56VG's which are made by Hammond, so I hooked one up. The 275 - 0 - 275 volt transformer makes 288 volts AC here. The B+ before the choke is 334 volts and 317 volts after the choke with a total current of 118 mA. The plate voltage is 312 volts. The cathode voltages are 23.3 volts and 22.8 volts, so the tube itself sees 289 volts. Tube current is 41 mA which works out to 11.6 watts plate and screen dissipation. Power output at 5% distortion is 2.3 watts. The sound is kind of wimpy. If I was going to run these tubes on this low of a voltage I would bump up the current and use a 3K ohm OPT.
OK, Which would I choose? I would go with the big guy, the 272JX, but that is just me, and I have one. You could use the 272HX or even the 272FX to lose a few more volts. You could use a 5U4G for the look, and lose a few volts over a 5AR4. Technically 333 volts is over the screen grid voltage rating, but this is usually OK in triode or UL mode. The 270HX would probably give you afew more volts than my 270FX, and this may be enough for your application especially if you are using a lower impedance OPT.
I recommend reducing the 10K ohm resistors in series with the CCS chips to 1K ohm on lower voltages. The CCS can run out of headroom on low B+ voltages with some 12AT7's.
While I had all this good stuff hooked up, I stuffed some other tubes in the amp. I tried some 6Y6's because they were in the same box as the 6L6G's. They really didn't like any of this, but they have a max spec of 200 volts. I usually use the Allied 6K7VG with 6V6's and 6K6's ant they work great, but I wanted to see how the tubes handled the big transformer.
The Allied 6K56VG makes 290 volts AC on the lighter load of a 6V6. The B+ before the choke is 335 volts and 320 volts after the choke with a total current of 100 mA. The plate voltage is 316 volts. The cathode voltages are 20 volts and 19.5 volts, so the tube itself sees 296 volts. Tube current is 36 mA which works out to 10.5 watts plate and screen dissipation. Power output at 5% distortion is 1.8 watts. The sound is excellent. These are ideal conditions for the 6V6.
The 272JX makes 326 volts AC on the lighter load of a 6V6. The B+ before the choke is 386 volts and 370 volts after the choke with a total current of 105 mA. The plate voltage is 366 volts. The cathode voltages are 23.3 volts and 22.4 volts, so the tube itself sees 343 volts. Tube current is 41 mA which works out to 14 watts plate and screen dissipation. Power output at 5% distortion is 2.5 watts. These are over the limit conditions for the 6V6. Fender ran the 6V6 this hard in the Champ and other amps, so good tubes should live. The sound is excellent. Bass and dynamics are better than the "normal" voltages.
Would I put my NOS pair of 6V6G's in here? No way! I don't mind toasting a Russian tube or two. Somewhere I have a NOS bulk pack of Sylvania waver base 6V6GTB's. I bought the box about 10 years ago, unopened. Upon opening the box, I found about 25 of the tubes had lost their vacuum. Since then about 20 more have turned white. I will toast some of these, since I can't trust them to live even in a nice cozy cardboard box.
The 6K6's bias up like the 6V6, but sound a bit different.
tubelab.com said:All tests were done in triode mode with a 5K ohm OPT...
OK, Which would I choose? I would go with the big guy, the 272JX, but that is just me...
Thanks for all your testing, and the detailed writeup. I plan on using a 5K OPT. You've convinced me I probably want the 272JX. What's your typical AC line voltage? Mine runs around 124 most days.
Is there a template for cutting out a chassis to fit the Simple SE board? Just the edges of the board, and the locations of the tube holes and mounting screws is all I really need. I've had good luck making Visio drawings if I've got the dimensions.
I forgot to post it. It was 122.2 and varying up and down about .5 volt during the testing. The outside temp was about 90F this afternoon. The voltage varies as the AC units cycle. 8 houses share a pole transformer, and mine is the furthest house from the transformer. During the winter my voltage can hit 124 or 125. On an August afternoon it can go down to 115.
I have a PDF of the silkscreen layer of the PC board. This is what I use for a drilling template. Print it, tape it to the chassis, and drill (or center punch) right through it. It is too big to attach here, and the forum doesn't seem to have a way to add attachments to its email, so send me an email and I will reply with the file.
Ty_Bower said:Could I use these Mouser parts?
647-UPW2W470MRD
647-UPW2W101MRD
I took a closer look. One of those caps has 12.5mm lead spacing, which isn't going to work well with the Simple SE board. I think maybe these would be a better choice:
647-UPW2W470MRD, 47uF, 450V, $3.67/ea.
647-UPT2W121MRD, 120uF, 450V, $4.40/ea.
This is also an option, but is currently backordered:
647-UPT2W151MRD, 150uF, 450V, $5.81/ea.
Keep in mind that all these Nichicon caps are only rated 450V, so don't try to use them with the "big" power transformer.
- Tubes / Valves
- Need ideas - 6L6GA & 6X5GT
