The Tubelab SE is using 5842 or WE417. Did anybody try the russian 6S45P ? The pinout is different, but the specs are similar.
http://tkhifi.homepage.dk/div/6S45P/6S45P.html Is this an option ? |
#2 | |
1. 6S45P 2. 5842 3. WE417
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#3 |
Most of us who have used both tubes find the WE417/5842 to be preferable in applications where its lower Gm is not a problem. Electrically, the 6C45 is closer to the WE437, which is quite rare and expensive, and probably not worth the effort. There are a couple of dozen pentodes that when triode strapped are also electrically similar (i.e., high mu, high Gm). 7788, D3a, 6688, etc.
#4 |
The 6S45P is easy to source and cheaper then the 5842.
The test results on vt52.com are good for the full audible audio range. http://www.vt52.com/info/measure/6s45/6s45.html There are also ebay vendors that clain the 6S3P and 6S4P are equivalent to the WE417. |
#5 |
I have built a headphone amplifier with the 6C45. I am using in the anode circuit a CCS (constant current source) design by gary pimm and a sowter transformer condensator coupled (parafeed) in the output. The sound of the amp is very good. I use a Sennheizer headphone HD650.
Further I have built the Euridice ( Italian design) preamp. Transformer coupled. In this amp I use the 3A/167M. This tube in the english equivalent of te WE 437 ( american) or the 6C45 (russian) or EC6020 (European). You can easily use the 6C45 in this amp. This amp sounds good. best regards, Jos |
#6 |
Hi guys,
Just wondering if anybody had used the 6S3P-EV ( aka 6C3n-EB http://www.mif.pg.gda.pl/homepages/frank/sheets/112/6/6S3PEV.pdf )? And if so, what operating points have sounded best? Any tips/advice appreciated. Thanks! |
#7 |
hey-Hey!!!,
I have used the 6S4p-EV. It is nice but quite a variable tube; you'll need a good batch in order to sort them for the better ones. cheers, Douglas
the Tnuctipun will return |
| 5842 - russian ripoff | wicked1 | Tubes / Valves | 7 | 20th March 2008 08:48 PM |
| 5842 and 5842 WA for 300B | massi68 | Tubes / Valves | 11 | 18th January 2007 10:41 PM |
| preference between 5842 and 6c45pi | dsavitsk | Tubes / Valves | 0 | 8th December 2006 09:43 PM |
| New 6s45p compare to NOS? | walkwalk | Tubes / Valves | 0 | 11th July 2005 01:48 PM |
| 6S45P matching | analog_sa | Tubes / Valves | 7 | 13th September 2004 08:37 AM |
