No Mistaking A Triode. - diyAudio
Old 14th March 2003, 03:11 AM   #1
G is offline G  United States
G's Avatar
Default No Mistaking A Triode.
Hi all'
I just got finished changing my amp to pentode mode and back. When in pentode mode it sounded like any SS amp that you can get at Circuit City or Best Buy. No Magic. No soul. Triode is the only way to fly. Now if only I could get someone to give me a set of Altec V.O.C.
G
Gavin
Old 14th March 2003, 07:02 AM   #2
Brett's Avatar
No argument at all here, and properly implemented DHTs are even better.
Lucky for me, I already have the horns. And the tubes.
If you can make it, you should stop in to the Midwest Audio Fest next month if you love tubes and horns. I'm going to try to make it next year.
I finished a little breadboard amp today. PP EL84 triode class A no NFB driven by a diff 6H30 using leftover parts from the junkbox and a pair of Z565 Dyna OPTs I was given by a kind soul. Sounds amazing for what it is, gives 3-4W and with some minor tweaking might be a keeper as my 'day' amp. I have a PP IT 300B under construction too.
Here's an article you might fing interesting.
Cheers
Old 14th March 2003, 12:00 PM   #3
Circlotron's Avatar
Why would IHT's sound better? Or is it that the only ones available are particularly good sounding? Technically at least, I would have thought that an indirectly heated triode would have sounded better courtesy of the whole of the cathode surface being at the same potential. But the fact is I have never critically compared the two. Can anyone edify me please?
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 14th March 2003, 01:15 PM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Whilst I follow your logic, it is known that DHT's have lower distortion than IDHT's.
I don't know why
Old 14th March 2003, 03:26 PM   #5
Default Good to know
I was hoping to hear from you on the pentode experiment.
Rick
Old 14th March 2003, 04:18 PM   #6
G's Avatar
Hi Brett,
My schedule for April is unfortunatly full this year but I also plan to go next year. I hope to see you there.
G
Gavin
DIY triode DSP_Geek Tubes / Valves 2 10th September 2008 06:03 AM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 05:31 AM
Help on triode croccodillo Tubes / Valves 1 31st January 2007 04:09 PM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 01:36 AM
ts9 pt9 triode desperateaudio Tubes / Valves 0 8th February 2006 07:58 AM
Copyright 1999-2017 diyAudio
