5670 SRPP DC coupled to 6S4A - diyAudio
Old 4th June 2008, 09:40 AM   #1
alexg is offline alexg  Philippines
alexg's Avatar
Default 5670 SRPP DC coupled to 6S4A
I attempted to draw a DC coupled 5670 SRPP into a 6S4a, any comments will be highly appreciated.
Old 4th June 2008, 10:35 AM   #2
5670 SRPP verry good I like the sound
your OPT are 6K
while the Ra of 6S4A here is about 3K
I suggest 9K -12K may have better THD and less Pout
and the Mu of 5670 is enough to drive 6S4A
so the coupplling Cap with 270R is not necessary
thats my experence
Old 4th June 2008, 11:54 AM   #3
alexg's Avatar
Thanks.
But I don't have a coupling capacitor, is taking out the cathode bypass capacitor what you meant?
Is my B+ voltage and cathode resistor computation for the 6S4A reasonable?
Old 4th June 2008, 12:07 PM   #4
Geek's Avatar
Originally posted by sam8888ysl
I suggest 9K -12K...
I'll back that up. A 6S4 isn't the finest sounding tube and could use the extra load, IMO.
Cheers!
Old 4th June 2008, 12:17 PM   #5
alexg's Avatar
Cheers!
How bad is the sound of a 6s4? I have not yet heard any equipment with this tube.
I have a few PL84 and 12b4 tubes too which I can use.
Am I better off using PL84 or 12b4 instead of the 6s4?
Old 4th June 2008, 09:46 PM   #6
Geek's Avatar
Try them all and see what you like.
PL84... that's a 15CW5 (not a 15V EL84 as the # suggests) and a different animal in the mix. Low voltage, current hungry little guy capable of 22W in a PP amp. Very clean. Trioded, even cleaner, but needs HUGE current at low voltage (for a tube). 1/4 amp for peaks
12B4 is a really, really sweet tube and given the choice, the one I'd grab unless I had substantial power iron for the PL84's.
I remember that day very clearly... I tested the 6S4A after testing 6AH4GT's and shuddered. The difference was night and day. Made the 6S4 into a power supply pass tube instead
Cheers!
Old 5th June 2008, 01:13 AM   #7
Originally posted by alexg
Thanks.
1. taking out the cathode bypass capacitor of 5670
2. higher B+ to got better THD
12B4 is very good and easy to built
7233 seems good too
even 5687 could work as power tube well
i have some 6s4 but i'll use them to drive some bigger power tubes not use them for power tube
Old 5th June 2008, 01:30 AM   #8
alexg's Avatar
Thanks for all the advise guys.
I have a few pairs of EL84, I might as well stick with them and use the 6s4 somewhere else.
I am having some custom power transformers wound for the PL84.
Hashimoto A-105 - 6S4A jazzbo Tubes / Valves 15 30th December 2012 12:21 PM
Has anyone tried a 6S4A as a 300B driver tube? MIKET Tubes / Valves 29 11th May 2012 05:58 PM
Diy Line Amp 5670 xiangyi Tubes / Valves 3 7th September 2010 02:49 AM
FS: Matched pair NOS RCA 5670 cartman Swap Meet 2 10th December 2007 09:12 AM
6s4a as driver for 6as7 in SEAmp alejo Tubes / Valves 8 23rd December 2004 10:08 PM
Copyright 1999-2017 diyAudio
