Gas coupling? - diyAudio
Old 3rd June 2008, 11:08 PM   #1
Default Gas coupling?
Has anyone employed gas coupling to provide a desired voltage drop from the plate to the grid of the tube in the next stage?
Old 3rd June 2008, 11:17 PM   #2
SY's Avatar
You mean with a neon bulb? Yes. Noisy, but it works.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 3rd June 2008, 11:18 PM   #3
No.
Robert McLean
Old 4th June 2008, 12:29 AM   #4
I was thinking VR tube
Old 4th June 2008, 01:16 AM   #5
rman is offline rman  Canada
rman's Avatar
Would't a VR tube keep the voltage constant and therefore
block the signal as well?
Rolf.
Old 4th June 2008, 01:37 AM   #6
SY's Avatar
No, the VR tube keeps the voltage drop across it constant. If there's always (say) 100V between anode and cathode, as the anode moves up a volt, so does the cathode.
Old 4th June 2008, 01:44 AM   #7
rman's Avatar
O yes of course
Coupling cap before or after pot? sharpi31 Parts 11 26th May 2008 06:02 PM
Coupling Cap 220F - the best is... Alfetta87 Digital Source 8 22nd October 2004 11:26 PM
ESP P3A coupling Brownlow Solid State 1 30th August 2003 08:46 PM
Coupling cap Raka Chip Amps 11 9th June 2003 01:06 PM
What does coupling mean? EternaLightWith Tubes / Valves 53 5th January 2003 09:35 PM
Copyright 1999-2017 diyAudio
