12ax7
12ax7
Old 31st May 2008, 10:48 PM   #1
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default 12ax7
I have seen a few comments on the 12ax7 being good for a guitar pre amp due to its warm sound.
Does anyone have a cct digram for a pre amp using this device ?
Some none linearity in the design to fatten up the sound would be good.
Thanks in advance, NIgel
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 31st May 2008, 10:55 PM   #2
AmpKiller66 is offline AmpKiller66  United States
The 12AX7 is probably the most common preamp valve in guitar amps today. All popular amplifier designs use them, so it's impossible to pick just one to give you. It all depends on what your preferences are. Here is a good starting point for guitar amp schematics. Just look up some of your favorite amps or the amps of your heroes.
My band Waffle Stomp: http://www.facebook.com/wafflestompband
Old 31st May 2008, 11:29 PM   #3
The Vox AC30 front end looks promising.
Many thanks........
Old 1st June 2008, 12:36 AM   #4
Many thanks........
Someone also sent me this link.
http://www.google.co.uk/imgres?imgur...&ct=image&cd=1
Old 1st June 2008, 06:06 AM   #5
Tubes4e4 is offline Tubes4e4  Germany
Tubes4e4's Avatar
V1b is loaded by 68k || 50k = 29k.
Tom
If in doubt, just measure.
Old 1st June 2008, 12:35 PM   #6
tubewade is offline tubewade  United States
tubewade's Avatar
I agree with Tubes4e4 that the output load is not ideal in that circuit. What does the feedback from the output valve anode to the input valve cathode do to the output impedance, though?
Old 1st June 2008, 02:54 PM   #7
I have altered the cct drastically just to use the first half of the valve. The second stage is no longer used.
12ax7Hide this!Advertise here!
12ax7 preamp. longji98 Tubes / Valves 20 13th September 2008 05:06 AM
12AX7 how many is enough? Sambeaux Tubes / Valves 19 23rd March 2007 07:31 PM
Sovtec 12AX7 rdr Tubes / Valves 13 6th January 2007 11:56 PM
Help! first tube pre-amp with 12ax7 zafira1981 Tubes / Valves 2 8th December 2006 09:37 PM
12ax7 Matthewong Tubes / Valves 0 12th June 2005 04:54 PM
