Edcor XSM10K/15K like intestage in tube SE ? - diyAudio
Old 28th May 2008, 09:08 AM   #1
Angelm is offline Angelm  Bulgaria
Default Edcor XSM10K/15K like intestage in tube SE ?
Hello, does anyone have experience with this transformer,
is it suitable for interstage in SE tube amplifier, 6SN7 to 300B ?
Specifications:
Maximum Input: 2.5 watts (RMS)
Input: 10,000 ohms
Output: 15,000 ohms
Frequency Response: 20~20,000 Hz, +/- 1 dB
Insertion Loss: 0.5 dB
Angel
Old 29th May 2008, 12:32 AM   #2
mwiebe is offline mwiebe  United States
I've used the XSM10K/10K as an interstage quite a few times, but not the 10K/15K. If you pull less then 2ma DC through the primary of the 10K/10K you can get away with series use, otherwise you need to parallel feed the interstage. If you use the 6SN7 I expect you will have to parallel feed it. You can use a CCS, resistor or a plate choke on the 6SN7 plate. Sounds much better then the cost suggests.
Matt
Edcor Transformers whitelabrat Tubes / Valves 23 9th September 2011 03:16 AM
Tube Mic Preamp - which Edcor transformer? pftrvlr Tubes / Valves 6 19th April 2009 07:43 PM
Edcor Site Down? Gone? anyone know anything? Trout Tubes / Valves 4 6th April 2009 10:36 PM
Edcor OPT's bloozestringer Tubes / Valves 23 3rd January 2007 06:27 AM
More Edcor XSM10K/10K Specs valveitude Tubes / Valves 8 16th October 2006 11:02 PM
Copyright 1999-2017 diyAudio
