how to calculate SE Coupling Cap Voltage ?
Old 27th May 2008, 08:22 AM   #1
calico88 is offline calico88  Indonesia
Default how to calculate SE Coupling Cap Voltage ?
I'm building SE amp and I just got 200V Caps, I wonder how to calculate the voltage wheater it's enough or not ?
any sample or url ?
cal
be tube
Old 27th May 2008, 11:54 AM   #2
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Coupling caps must have a voltage rating greater than the supply voltage (HT).
Because, if the valve reaches cut-off, or if it is not plugged in, or if the cathode is not warm, the anode voltage will rise to the supply voltage.
I suspect your 200V capacitors will not be sufficient, however, it may be possible to connect two in series to raise the voltage rating...
Old 27th May 2008, 05:34 PM   #3
the B+ is 125Volt, it's a 0.8 Watt amp. SE.
using 6247 and 5902
is not enough ?
I don;t know how to calculate.
cal
be tube
Old 27th May 2008, 11:48 PM   #4
Merlinb's Avatar
using 6247 and 5902
is not enough ?
cal
Then 200V will be OK on normal resistor loaded stages. (But not choke loaded stages- but I don't think you have one of those.)
how to calculate SE Coupling Cap Voltage ?Hide this!Advertise here!
How can I calculate voltage over cathode resistor? Nordic Tubes / Valves 27 30th April 2008 11:44 AM
using voltage drop to calculate current cbutterworth Power Supplies 2 3rd September 2007 02:21 AM
How can I calculate input noise voltage and current? thanh Solid State 0 8th July 2004 05:34 AM
Choke-Input: How do I calculate the right snubber for high-current-low-voltage Blitz Solid State 20 24th March 2004 09:37 PM
Copyright ©1999-2017 diyAudio
