Hi - I'm a newby here and am excited that I found this site - excellent material and help!!!
I posted a reply under chip amps that also poses a question and wonder if it would better be posted under this subject since it really involves tubes. My question relates to a build it project in the January 2008 audioXpress magazine. It is the Hybrid Hi-Fi Power Amp by Bill Christie. When I reviewed the schematics for this design, I noticed that several components did not match up with the parts list or photos. For instance, there are two 820uF caps in the power supply that are listed in the parts list and are shown in the photos, but the schematic showns four 80uf caps. Also, there is a xformer on the schematics not present in the parts list or photos. Has anyone built this amp yet and encountered any problems? I don't subscribe to audioXpress (yet) so I don't know if there has been any corrections printed. Thanks for your help!!! |
#2 |
link to the article?
schematics? I can't find anything |
#3 |
Hoka:
As best I can tell, this article is not available on-line, but the PC board with component layout and chassis wiring diagram is. Here's the link: http://www.audioxpress.com/magsdirx/...enda/index.htm Scroll down the page and you'll see the name of the article and the two figures beside that. 1/08 - A Hybrid High-Fidelity Power Amplifier - Bill Christie The wiring diagram shows the different components as I mentioned that do not match the parts list, schematics or photos. I may be able to scan the schematics and post them if that would help (although that may be a copyright issue that I wouldn't want to violate)! Thanks for your help! George |
#4 |
Probably best not to do that. You could scan an excerpt from the schematic, the small section in question for the purpose of clarification. But the first thing I'd do is write the author.
If there's a sucker born every minute, where do the rest of them come from? |
#5 |
SY:
My first attempt at getting some clarification had been to search for Bill Christie and then contact audioXpress, but 1) I could not find an address for Mr. Christie and 2) audioXpress has not replied.... So... I figured I'd try this group to see if anyone had built the amp. Thanks George |
#6 |
www.isaharr.com |
#7 |
Nope - the one I'm looking at uses a LM4702 front end and two KT88's and was published in the January 2008 issue.
#8 |
Maybe I should try this a different way - does anyone know how to get in touch with Bill Christie?
| Hybrid Car Amp... let's try | jeppix | Car Audio | 19 | 18th August 2008 05:48 PM |
| the hybrid one | arhi45 | Tubes / Valves | 11 | 8th May 2007 08:44 PM |
| Hybrid Ply / MDF ? | Renron | Multi-Way | 5 | 8th February 2007 10:49 PM |
| My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. | Spasticteapot | Multi-Way | 0 | 30th November 2006 04:16 AM |
