diyAudio Sponsor
Old 25th May 2008, 01:58 PM   #1
Default Replacing a cathode resistor with a CCS
I haven't played with CCS's before so I need some guidance so I can learn. I will try to attach a schematic.
I would like to replace the 54.9K cathode resistor that is being shared by the 6SL7 with something better. I have 71 volts between ground and pins 3 and 6 of the 6sl7. I believe this will result in .0012932mA
Will this primative transistor,zenier and 2 resistor combination work or is there something better out there that will provide better results?
Old 25th May 2008, 02:12 PM   #2
Original circuit
Old 25th May 2008, 04:08 PM   #3
SY's Avatar
You've got some volts to work with, so that's a good thing. Your scheme will work, but to make it optimal you want the Zener voltage to be fairly large so that the emitter resistor is also large- that increases the source impedance by roughly hfe times Re.
One neat trick is to tap the DC voltage feeding the reference off the plates of the diff amp through symmetrical resistors - that way, common-mode stuff is partially canceled.
I think you mean 1.29mA, not 0.00129mA.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 25th May 2008, 04:21 PM   #4
SY
Thank you for your reply.
Would the HV NPN CCS circuit work here? If so would it be better?
Yes, I meant 1.29mA
Old 25th May 2008, 04:33 PM   #5
SY's Avatar
Do you mean the cascode? If so, yes, but you can easily hit diminishing returns. If we take a single NPN with an hfe of 150, and we use a couple of LM329s in series as a reference, the emitter resistor will be about 13k. So the source impedance will be roughly (150)(13k) = 1.9M. Not bad, especially compared to the cathode impedance.
Old 26th May 2008, 01:31 PM   #6
Are there any PCB available from anyone? I really would like to assemble something that looks neet instead of having a cluster farce of flying components.
SY,
Thanks for the response. I appreciate the fact that no one else would respond and you took the time.
Old 26th May 2008, 03:10 PM   #7
Originally #5 posted by SY
If we take a single NPN with an hfe of 150, and we use a couple of LM329s in series as a reference, the emitter resistor will be about 13k. So the source impedance will be roughly (150)(13k) = 1.9M. Not bad ...
Sorry SY,
you should correct this one!
Kind regards,
Darius
Old 26th May 2008, 09:00 PM   #8
Geek's Avatar
Anyone notice there's no DC return for the grids in that schematic?
Old 26th May 2008, 09:05 PM   #9
SY's Avatar
Originally posted by oldeurope
Sorry SY,
Kind regards,
Darius
You're right, it's a bit higher than that since I neglected the 1/hoe term. But hfe time Re dominates.
Old 26th May 2008, 09:07 PM   #10
SY's Avatar
It's a fragment. The grid is direct coupled from the plate of a voltage amplifier.
SE 6V6 cathode resistor value bereanbill Tubes / Valves 7 24th May 2009 05:11 PM
TVA-1 cathode resistor value audiohead Tubes / Valves 3 9th December 2007 08:15 PM
Replacing a 12AU7 in a cathode-follower. beppe61 Tubes / Valves 51 28th March 2007 09:05 AM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 06:21 PM
Problem with cathode resistor liberty Tubes / Valves 3 9th September 2005 02:37 AM
Page generated in 0.09840 seconds (81.61% PHP - 18.39% MySQL) with 11 queries
