Old 23rd May 2008, 08:59 PM   #1
bigwill is offline bigwill  United Kingdom
General Nuisance
Question Generating big voltage swings without 'iron'
I've been looking at cathode follower based output stages and thus trying to figure out a way to generate the large driving voltage required. I saw something on John Broskie's TubeCad website that had some sort of arrangement with 6SN7-esque triodes in series to generate large swings, and counteract the max plate voltages of the tubes. I've been trying to find this but many google searches have turned up nothing!
What ways are there to generate such swings, say on the order of 400v p-p or more, without transformer or inductor loading?
Old 23rd May 2008, 09:35 PM   #2
DougL is offline DougL  United States
In order to get 400V p-p with a resistive or active load, the rule of thumb for triodes is to have a minimum 600V supply. Triodes swing about 2/3 B+. You also need a tube rated for an absolute minimum of 300V plate. The 6SN7 rated for 450V is a good choice, as well as some of the TV tubes have voltage ratings up to 550 V plate.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 23rd May 2008, 09:38 PM   #3
General Nuisance
Thanks for your reply Doug. With regards to max plate voltage, can this be briefly exceeded under transient conditions ie signal peaks? What actually happens if you go above this voltage?
Old 23rd May 2008, 09:42 PM   #4
luvdunhill's Avatar
What about something like the 6S4A
Old 23rd May 2008, 10:05 PM   #5
The max plate voltage is the maximum DC voltage The tube can tolerate twice this voltage as AC.
I was thinking about that tube when I replied. However, I know there are different but comparable tubes across the pond.
Old 23rd May 2008, 10:26 PM   #6
General Nuisance
What determines the max plate voltage on a tube? Tendency to flash over, or is it a dissipation issue? I have some cheap russian 6SN7-alikes I'm not scared to try running at high voltages..
Old 23rd May 2008, 11:01 PM   #7
luvdunhill's Avatar
ooh? pray tell what those might be what about 3D21A?
Old 24th May 2008, 01:32 AM   #8
I would suggest a bit of bootstrapped positive feedback, similar to what is done in the McIntosh driver stage. It's a good simple way to achieve large voltage swing, without having very high B+ voltage. Pentodes might be a better choice than triodes, as they can swing a large voltage more easily.
Old 24th May 2008, 03:19 AM   #9
Miles Prower's Avatar
Default Re: Generating big voltage swings without 'iron'
CCS loading. I had the same problem with an 845 design. That requires a swing of 310Vp-p to get it to max power. Here's a loadline. 6BX7 CC Loadline
Of course, without xfmrs or inductors, you will also need lotsavolts as well. In this case, I used a 6BX7 -- a vertical deflection type that can handle that. It operates off a +/- 410Vdc supply.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 24th May 2008, 01:24 PM   #10
General Nuisance
Just to throw a spanner in the works, how hard would it to be to generate large differential swings? Like a CCS loaded phase splitter...
The most linear stage for large voltage swings - Lender's Circuit tiefbassuebertr Solid State 45 7th April 2013 02:27 PM
Heater to Cathode max voltage specs, including signal swings? flysig Tubes / Valves 2 28th June 2009 09:22 PM
generating PWM frozenpod1 Class D 3 29th August 2005 07:09 PM
Class D handle the impedance swings of ESL57s? amt Class D 1 7th August 2005 06:15 AM
Variable Voltage Technology(uk) iron argo Tubes / Valves 4 6th January 2005 12:08 PM
Page generated in 0.25535 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
