Anyone built a tube-based (6BE6 or 6HS8) volume control?
Old 23rd May 2008, 12:52 PM   #1
GordonW is offline GordonW  United States
GordonW's Avatar
Default Anyone built a tube-based (6BE6 or 6HS8) volume control?
I'm building a preamp... had originally planned to build the Marantz 7 circuit (simplified, no tone controls or loudness/rumble filter etc)... but after thinking and looking around, I'm thinking of making a change in the line stage (leaving the Marantz phono stage as original, though).
Has anyone here built one of THESE (tube-based volume control)?
http://home.netcom.com/~wa2ise/radios/6be6vol.html
My main question is- how quiet is it? Pentode partition noise? Hiss?
Also, how linear does it seem to be, passing sound at different volume levels?
Thanks!
Gordon.
Speaker Design, Restoration and Repair- since 1985.
Old 24th May 2008, 07:39 AM   #2
oldeurope is offline oldeurope  Germany
Hello Gordon,
you started an interesting thread.
At the moment I am making a tube based volume control, too.
I think noise is not the problem here, because the input level at
grid 1 is high and the anode load resistor fairly low to get no gain.
The main problem I see is only 50db attenuation. This is not enough.
In my project I need a phase inverter triode that has ideally unity gain.
I didn't find one, thus I am going to use the 6080 as an phase inverter.
I hope it makes no hum from the filament ...
Kind regards,
Darius
Old 28th May 2008, 12:11 PM   #3
GordonW's Avatar
I was looking at that... which got me thinking of using two 6BE6s per channel, for a total of 100dB attenuation. I'd think that would do it. This would also put the signal back in-phase...
After considering it further, my question, now, really is, what is the output gain at full-output from these? IOW, can I use two of these cascaded, to form a preamp line gain stage? Or, would I have to get additional gain somewhere else? If I have to add more tubes for more gain, it becomes far less attractive...
Gordon.
Old 28th May 2008, 01:39 PM   #4
Default #3
Hi Gordon,
Yes.
Gordon.
you can increase the gain be increasing the 22KΩ resistor
at the anode.
Kind regards,
Darius
Old 28th May 2008, 04:11 PM   #5
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Look at: http://www.diyaudio.com/forums/showt...threadid=37499
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 28th May 2008, 05:59 PM   #6
GordonW's Avatar
Anyone got a handle on how to calculate gain for a 6BE6 wired this way? I've been looking around, but I can't quite find the procedure... I can find data on the tube used as a converter or oscillator, but obviously, not wired like this...
If I just knew how to get the transconductance and effective plate resistance in THIS mode, I could take care of the rest, I think...
Gordon.
Old 29th May 2008, 06:05 AM   #7
Thanks for the link.
Darius
Old 29th May 2008, 02:11 PM   #8
foboleyns is offline foboleyns  China
Send a message via MSN to foboleyns
hey,
here is the circuit my used with a pair of chinese 6J2. 6AU6 be able to instead without modify.
Old 31st May 2008, 09:24 AM   #9
Originally posted by foboleyns
hey,
Hello, thanks for your schematic.
I have two questions.
Can you hear the steps when adjusting the volume?
Why didn't you use a regulating pentode like e.g. EF83 6K7 6DA6 ... ?
I can't find any tube data for the 6J2.
Kind regards,
Darius
Old 11th August 2013, 10:04 PM   #10
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Hi
Old thread but wondered if anyone tried foboleyns design above?
Looks interesting........another project maybe!
If you keep digging in the garden of failure you will eventually find success
Anyone built a tube-based (6BE6 or 6HS8) volume control?Hide this!Advertise here!
how is the quality of a chip-based volume control VS normal stepped attenuator? jarthel Parts 4 16th July 2007 02:40 PM
6HS8 tubes for volume control jkeny Tubes / Valves 12 23rd February 2007 10:38 AM
speakerUsing wall-mounted transformer-based volume control in preamp? KT Parts 1 4th March 2006 11:44 PM
Transformer-based volume control wboyd Analogue Source 4 18th August 2004 04:57 PM
Relay-based passive volume control project BrianGT Everything Else 110 1st March 2003 01:27 AM
Copyright ©1999-2017 diyAudio
