diyAudio Sponsor
Old 12th March 2003, 06:30 PM   #1
Zombie is offline Zombie  Sweden
Question Standby switch for Quad II?
Hello!
If anyone here has any ideas where to put a "standby" switch on a Quad II, please reply to a novice.
The idea is to shut off everything (B+?), except the heater voltage to keep the valves warm.
I saw smth here with ICs etc. (Jukka Tolonen's), but I'd rather just have a simple switch.
Thanx,
Tom
Old 12th March 2003, 08:25 PM   #2
7N7 is offline 7N7  France
7N7's Avatar
If your aim is simply to allow th valves to warm up longer, then a simple switch could be used, although with an indirectly-heated rectifier it's not really worth it.
You must not leave the valves on with full heater voltage for long periods; this will cause cathode-poisoning.
If you wish to leave the valves on permanently, then they must be run at about 60% of the heater voltage (i.e. about 4v).
This means that a "simple switch" will not do.
7N7
Plug them in and light them up
Old 12th March 2003, 11:17 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Default SOFT START.
In a way a simple switch would do just fine, namely the ON/OFF switch.
Since the QIIs use the GZ32 valve rectifier it has a built in soft start, I can't really think of any reason why you'd want to change that.
What is your concern? Valve life? Warm up time?
Frank
Old 13th March 2003, 12:44 AM   #4
7N7's Avatar
Default Re: SOFT START.
Frank:
This is what I said in my message - in different words admittedly!
7N7
Old 13th March 2003, 12:47 AM   #5
fdegrove's Avatar
Default SAME, SAME, DIFFERENT.
Sorry for not being so tactful when it comes to potential valve destruction.
No offense,
Frank
Old 13th March 2003, 07:47 AM   #6
Thanx for the replies!
I mainly thought about extending the life of the valves and also to provide a soft-start every time I bring home a new batch of NOS GEC KT66s, of course
Fdegrove, 7N7: would you please elaborate the built-in soft start in the Quad II using GZ32 (GZ34?)? How does that work?
Tom
Old 13th March 2003, 09:15 AM   #7
7N7's Avatar
Default Virtual Soft Start
Tom
Quad II is fitted with a rectifier valve. This is a GZ32, an indirectly-heated type. This rectifier takes perhaps 15 - 20 secs to warm up before it will pass current. The current increases as the valve warms up therefore a soft start is guaranteed.
Meanwhile all the other valves have been warming up too, and should have reached probably >80% of their operating temperatures, ergo no problem.
As I mentioned earlier, if you want to leave the valves idling, i.e. with heaters on but no HT, then you must arrange things so that they idle at about 60% of normal heater voltage.
7N7
Old 13th March 2003, 09:22 AM   #8
Thank you!
One learns something new every day
I assume it goes for the GZ34, too...?
Tom
Old 13th March 2003, 09:38 AM   #9
7N7's Avatar
Thank you!
Tom
Yes it also applies to GZ34. However rectifiers do differ; 5U4 for example is directly heated and current will flow sooner than with the indirectly-heated types.
7N7
Old 13th March 2003, 11:43 AM   #10
7N7
If I remember rightly, (and I admit I'm desperately trying to remember a circuit I saw 20 years ago!) it is possible to have an idling voltage for the valves by placing a half-wave rectifier (a standard silicon rectifier) in the heater leads. So long as there is no cap smoothing, the rectifier will pass half cycles at RMS voltages only, so 3.15v x 1.414 = approx 4.5v, enough to keep the valves warm without risking cathode poisoning. Then a simple switch wired across the rectifier will give the normal/idling voltage control.
The explanation may not be brilliant but the use of a half wave rectifier as a 'voltage dropper' did enjoy some success in old AC/DC radios as it meant you could reduce heat by avoiding a resistor dropper in the heater leads. It has also been used as a method of having an idling voltage on soldering irons, to keep them warm in between use and reduce warm-up time.
standby switch 9am53 Tubes / Valves 17 25th October 2010 01:24 PM
Where do you put the standby switch duderduderini Tubes / Valves 13 4th October 2008 05:39 PM
Standby Switch dre7 Tubes / Valves 6 18th October 2007 09:07 AM
Standby switch elementx Tubes / Valves 6 24th January 2006 04:46 PM
Page generated in 0.12365 seconds (80.65% PHP - 19.35% MySQL) with 10 queries
