Hi Nick,
You might look around at the link below. Both numbers are GE tubes. The files are big and I've got dial-up.
http://www.house-of-tubes.com/home/library.asp
Also, the two numbers above are usually used as series pass tubes. The error amp rarely sees more then a reduced level sample of the output when used in a feedback regulator scheme. The gain of the stage makes up for that reduced level to provide good control.
Ah-ha, I found these:
http://catalog.rell.com/rellecom/Images/Objects/6600/6544.PDF
http://catalog.rell.com/rellecom/Images/Objects/7400/7327.PDF
Also 6842:
http://catalog.rell.com/rellecom/Images/Objects/6600/6557.PDF
If the links won't work directly, go to www.rell.com >industrial>vacuum tubes>search online catalog
Victor
Also 6842:
Victor
