no coupling caps
no coupling caps
Old 20th May 2008, 05:59 AM   #1
ray bronk is offline ray bronk  United States
Default no coupling caps
Hi all,
Was wondering if anyone has come up with a way of routing or nulling out the VDC that would be at the output of a Tube preamp's stage, so you do hnot have to use a coupling cap at the outputs?
Ray Bronk
Old 20th May 2008, 06:46 AM   #2
cerrem is offline cerrem  United States
cerrem's Avatar
Typically you use a negative supply on the tail of a CCS acting as the load for a Cathode Follower....
Adjust for 0 volt out.....
The trick to keep the circuit locked in from drifting is closed loop feedback ......Output is DC sampled and sent to error amp to control the CCS grid....
Chris
Old 20th May 2008, 07:10 AM   #3
Hi Chris,
Well, I am looking at getting a GGP, and was thinking if only I could get rid of the damn coupling caps. It's using 12AU7 tubes. So probably to do what I want is probably not worth the effort. But I thought I'd at least ask.
Ray Bronk
no coupling capsHide this!Advertise here!
Coupling caps. Trebla Class D 5 1st March 2006 09:12 PM
Pre-amp coupling caps Bill Fitzpatrick Parts 15 4th March 2005 11:54 AM
coupling caps el capitan83 Parts 10 17th December 2004 04:25 PM
coupling caps??? AudioGeek Parts 14 16th September 2004 12:05 PM
What value for the coupling caps? roibm Parts 12 23rd March 2004 05:58 PM
