| diyAudio Sponsor | ||
What kind of mu do you need for an error amp in a tube voltage regulator. Is anything over 100 good?
Thanks, Nick |
#2 |
Pentodes are ideal here. The higher the amplification, the better. Take a look at some of the regulators that Tek used to use.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#3 |
Is a triode with a mu of 100 good, my problem is the voltage around 1 to 1.5 kv.
I have found a few triodes that will do this but no pentodes so far. How do you compare the amp factor of a pentode to a triode, if it's even listed for the pentode. All the ones I have looked at to are very low like a mu of 6 to 10 for pentodes. I will take a look at some old Tek schematics but if memory serves they did some funky stuff with the high voltage or nothing at all. Thanks Nick |
#4 |
SY I looked at a few TEK tube scope schematic for reference as you said.
Out of the 2 I looked at all the error amp tubes were 6au6's and it's mu is 36. The question I have is can I use a triode for this application if it has a high mu say 100 or 150? Thanks, Nick |
#5 | ||
Example: 6CB6: rp= 280K gm= 8.0mA/V u= (280E3)(8E-3)= 2240 They don't list it for pents or solid state since it's not very useful for anything but triodes since only triodes exhibit significant Ip change with varying Vpk. Calculations for devices other than triodes use gm. (You can also use gm with triodes as well, if you so desired.) Quote:
#6 | |
Victor
"The human race is just a chemical scum on a moderate-sized planet orbiting round a very average star in the outer suburb of one among a hundred billion galaxies." ~Stephen Hawking |
#7 |
nhuwar, a 6AU6 will give a gain MUCH higher than 36, since they use it as a pentode, not a triode. At 4-5mA/V transconductance, a 100k plate load resistor will give a gain of 400-500.
#9 |
6CB6A's are great for this. Can be had really cheap too. Here's a decent performing reg using a high-mu triode/pentode: http://geek.scorpiorising.ca/GeeK_Zo...p?topic=3665.0 Steve Bench has great examples too. Cheers! |
#10 |
Keep in mind the stability of the closed loop system.... You need to calculate the compensation values to maintain a safe and stable loop.... You can plot your POLES and ZEROS on a BODE plot if you prefer graphical representation....
The objective is stay above 60 degrees of Phase Margin at your cross-over frequency... and better than 15 degrees of Gain Margin.. Chris |
| Series MOSFET regulator better with just voltage ref on gate or with error amp? | ray_moth | Tubes / Valves | 69 | 20th May 2011 02:35 AM |
| FOR TUBE: 350V High Voltage Regulator | uhcmos | Swap Meet | 26 | 6th February 2010 05:28 AM |
| Tube Voltage Regulator Flicker... | sonata149 | Tubes / Valves | 14 | 3rd March 2007 08:22 AM |
| Tube Voltage Regulator Design | CarlyBoy | Tubes / Valves | 61 | 30th October 2006 04:31 PM |
| Tube for a shunt voltage regulator | jarthel | Tubes / Valves | 14 | 26th October 2006 05:19 AM |
| Page generated in 0.11048 seconds (80.73% PHP - 19.27% MySQL) with 10 queries |
