Folks,
I'm looking for a summer project. What do you think of a DC coupled EL84 to 10Y output, similar to the one in the link below?
http://www.tubemaster.de/e-diy-EL842A3.html
Alternatively, I am also contemplating a Yamamoto style 717A cap-coupled to a 10Y output - even though I am not yet convinced about the sonics of this combination - I think it may sound kind of thin...
The EL84 is a very musical tube and I think it would pair u well with the 10Y's extended highs. What do you think?
TIA,
-- josé k.
TIA,
-- josé k.
korneluk said:I'm looking for a summer project. What do you think of a DC coupled EL84 to 10Y output, similar to the one in the link below?.
If you are going direct coupled, here's a thread that might be interesting: http://www.diyaudio.com/forums/showthread.php?s=&threadid=123211
Save you some iron.
Sheldon
My only worry is that the EL84 will not be able to drive the 2a3 to full power.
Not much of a worry when the 2A3 will give 2.5 watts and a EL84 pentode is over 5.
astouffer, since the EL84 is being used as a voltage amplifier, its "wattage" is beside the point.Not much of a worry when the 2A3 will give 2.5 watts and a EL84 pentode is over 5.
I ran the circuit through tube CAD. I got an Av of 11.5 with the values listed. Multiplying that by 2 Vrms output "standard", it results in 23 Vrms to the grid of the 2A3.
Plugging 70V peak into SE CAD with a 2A3 Fixed Bias with 250V on the plate shows signs of clipping, and 3.75 watts RMS
So it appears that the gain is just enough for full output.
HTH
Doug
I fully understand that in pentode mode the EL84 has higher power than 2a3, but EL84 as a driver fed with at the max of 2V from a CD player, would it develop enough voltage swing to drive the 2a3 to full power?
