| diyAudio Sponsor | ||
#11 | |||
And conect the wiper (midle pin) to the grid of the input valve... Quote:
Regards. PS: pay atention at charged capacitors and high voltage...sorry but i donīt know your knowledge... Sorry i forgot...the tone control is RV2...and yes is the circuit in shiFtYs schematic link!
Jorge |
#12 |
Thanks for the spoon feeding Dude,
Okay so I changed the schematic to what you suggested, I believe. Check this out. amt |
#13 |
Fine!!!!! only RV7 need to be a 470k...not a pot...less noise!
Go to it!!!
Jorge |
#14 |
Does the wire between the tube still remain in place and if so, which side of the resistor does it connect?
(last question I think?) thanks amt |
#15 | |||
Be my guest... motorcycle friend
Jorge |
#16 |
Also one thing I found is that the negative feedback resistor (R9) is quite variable: you can leave it out all together if you wish. I found around 10K sounded good (a tiny amount). You can play around here- but don't go too low (I didn't go below 5K)
The Akai output transformers have only the 8ohm winding for speakers, so you have to take it from there. (Many other transformers have taps for 4, 8, 16 ohm) Also another tip- when you first fire it up, use the crappy akai speakers for testing purposes, in case you have made a mistake. Oh, and also never run a valve amp without speakers Make sure you keep us posted! |
#17 | |
The original Mullard had a feedback resistor of 3.3k from a 4 ohm winding, so from 8 ohm output it should be 6.6k to keep the original 6db feedback ratio, but if gain is not a problem you could probably reduce this resistor to well below 5k. |
#18 |
frugal-phile(tm)
I have 2 Roberts branded 6BM8 R-R amps. The 2 12AT7s are part of the pre-amp circuit and aren't required.
I also have a little Calrad 6BM8 SE... it is quite a nice little amp (even stock and in need of attention). The circuit posted was the one i was going to leverage for my units -- the designer is no slouch. The Japanese are quite enamoured of the 6BM8 -- you can probably find some more references. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#19 | |
http://www.worldaudiodesign2.co.uk/pdf/kecl82.pdf |
| AKAI Digital audio parts- pcm61P/encoders/boards | imix500 | Swap Meet | 10 | 31st December 2011 10:58 PM |
| Parts mined from an AKAI 1800L, what to do? | keantoken | Tubes / Valves | 13 | 18th March 2009 11:52 PM |
| Akai 'Boombox' AJ 505 parts needed | Audiofirst | Solid State | 0 | 24th July 2007 12:09 PM |
| Got parts? No what do I build | PeterK | Subwoofers | 9 | 10th July 2005 09:22 PM |
| what amp to build with these parts ? | Groundloops | Solid State | 1 | 28th May 2004 03:24 PM |
| Page generated in 0.10185 seconds (81.33% PHP - 18.67% MySQL) with 11 queries |
