In the TubeCad journal his designs use an FET CCS. All he says is "FET constant current sources are readily available in two-lead packages up to 100V's and in increments up to 4.7 mA"
I searched digikey and mouser and found nothing like this. Anyone have an idea what he is talking about ? |
#2 |
Search for constant current diode or CCD.
Non é mai abbastanza... |
#3 |
An example is the Siliconix J500.
Dave |
#4 |
I use the 1N5283 ... 1N5314 series current regulator diode. A 3.9 mA and a 4.3 mA diode is connected parallel in the cathodes of a long-tailed pair phase splitter (E88CC), and they are connected to - 50 V. I think Motorola, ON Semi, Knox and others produce this range of CCS diodes.
#5 |
I imagine they can be paralleled to go higher than 4.7 mA ?
#6 |
Careful now, SY hates those things. They are basically N- channel JFET's with the gate tied to the source, and sorted for IDSS, or limiting current. For some purposes they are probably quite adequate, but if they are directly in the signal path, you can do much better. A simple N-channel FET with a source resistor is better, but still simple and adjustable by changing the source resistor. Cascoded N-channel JFET add one more part and increase impedance and noise rejection further. Full explanation provided here: http://www.audioxpress.com/magsdirx/...a/jung2778.pdf
Sheldon |
#7 |
#8 | |
They are current sources with mediocre source impedance andmoderate voltage ratings. They aren't cheap. For the cathode CCS in your second stage, they'll be adequate since it is shunted by the load that you're using the preamp to drive. The plate CCS ought to be something better. I'd use either cascoded DN2450 MOSFETs (easy to self-bias) or cascoded bipolars. They won't add much to your power supply load (the self-biased MOSFET won't increase power supply load at all), they are cheap and simple, and the performance will easily exceed the two-terminal devices. You can also get rid of the resistors you show in series with the CCSs. If the CCS voltage rating is sufficient, the resistors are redundant.
If there's a sucker born every minute, where do the rest of them come from? |
#9 | |
Thankyou, I figured those resistors were just there because he was using a 100V device. My B+ is only 180V, if I understand this circuit all I have to do is make sure the CCS and the cathode resistor are balanced (same current draw) ? |
#10 |
The CCS will set the current through the tube and cathode resistor. The size of the cathode resistor is chosen to provide the desired cathode bias voltage, E=IR.
There are three parameters, plate current, plate voltage, and bias voltage. You get to pick two and the tube picks the third. The plate voltage is really plate-to-cathode voltage, but I usually think of it as plate voltage because the difference is only a couple of volts. Dave |
| Mod journal for sl1364 5.5 " Midwoofer | OlogyAudio | Multi-Way | 2 | 17th September 2008 10:46 PM |
| Tube Cad Journal dead | reinhard | Tubes / Valves | 5 | 21st March 2006 12:56 AM |
| Article in Int. Journal of Electronics | jan.didden | Solid State | 11 | 27th October 2005 06:27 AM |
| Wanted: Original T/S Journal | sianturi | Multi-Way | 7 | 22nd July 2002 02:09 PM |
