6SN7 coin base tubes
Old 17th May 2008, 03:44 PM   #1
Burnedfingers is offline Burnedfingers  United States
Default 6SN7 coin base tubes
I just found a sleeve of the coin base 6SN7 tubes in the garage. Are they worth using or should they be ebayed?
Old 17th May 2008, 04:21 PM   #2
aerius is offline aerius  Canada
Keep them around as guinea pig tubes, use them while testing out new circuits or in any other situation where you don't want to accidentally blow up an expensive NOS 6SN7. Say for instance you bought a used amp and you're not sure if it's OK or if you suspect it may have shipping damage, pop in the coin base tubes, fire it up and see if it makes sound. If it works, great, if it does blow up, at least it didn't take your good tubes with it.
Old 17th May 2008, 05:35 PM   #3
kmtang is offline kmtang  Canada
kmtang's Avatar
Well, it would say just try them out. I have a pair myself made by ECG.
Johnny
Old 18th May 2008, 01:00 AM   #4
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
You mean the very small base, like on metal tubes? I've always called it "wafer base", not sure if that's correct...
like this:
6SN7 coin base tubesHide this!Advertise here!
asking about 6sn7 and 2a3 tubes Pocoyo Tubes / Valves 10 24th August 2009 10:37 PM
FS: 5691, 6L6, 6SN7, CV1985, more tubes Doctorcilantro Swap Meet 0 16th March 2009 04:16 PM
Wanted to buy 5691 red base tubes Burnedfingers Swap Meet 0 6th March 2008 12:07 PM
6SN7 tubes horn150 Tubes / Valves 1 25th January 2003 05:32 PM
