General Nuisance
I took one of the EL84s out in each channel of my stereo 20. It goes just as loud and actually sounds much BETTER, especially in the way it clips. WHAT?
WHAT??! |
#2 |
Perhaps you just changed the distortion from symmetrical (odd order) to non- symmetrical (even order). This is largely the difference between single ended and double ended(push-pull) output stages, although probably to an even greater degree in your instance since the output transformer was not designed for this.
Since each valve has his own cathode resistor, no harm will come from running the amp this way. If the cathode resistor were shared by both valves the current though your lone 6BQ5 would be too high and would probably result in an angry red plate. Wade |
#3 |
General Nuisance
It still sounds clean, and the bass is still present in spite of the magnetic bias in the OPT. When I tried it I just did it for a laugh to see what it sounded like but I was surprised that it actually sounded pretty good! I did check the schematic before pulling out one half of the output stage to ensure nothing harmful would happen and as you said, it is safe to run it like this and quite frankly I enjoy the sound!
#4 |
Be careful - the ST20 output transformer is fairly marginal for the original design, and often fails. Putting a DC offset through it isn't going to help
#5 |
General Nuisance
Could you elaborate? I'm having trouble understanding how it could potentially damage the OPTs. Does having a magnetic bias present a problem? (Other than possibly magnetising the core)
#6 |
diyAudio Moderator Emeritus
I'd be surprised if it did harm to the OPT. On the other hand, it will relieve the power transformer of some of its load, which might not be a bad thing.
#7 | |
I'm not sure how you degauss a transformer. Maybe you can just run it normally, but at low levels for several hours? |
#8 |
You could just buy some relatively inexpensive SE transformers and plunk them in if you plan on making the switch permanent... If you've decided you like the sound, you should do that instead of messing with your PP transformers.
| Using an output tranny from a stereo for a single-ended amplifier ? | bereanbill | Tubes / Valves | 1 | 3rd April 2009 03:15 PM |
| Running Single Ended 6V6 in Triode Mode | WRyan | Tubes / Valves | 19 | 10th February 2009 05:09 PM |
| Running stereo through a single tube with dual triodes? | RockysDad | Tubes / Valves | 2 | 21st January 2009 12:47 AM |
| single ended HiFi Regal stereo tube amplifier | karma | Tubes / Valves | 20 | 14th June 2005 02:59 PM |
| FS: 300b single ended stereo amp w/tubes | Magnetmaz | Swap Meet | 1 | 21st July 2004 04:31 AM |
