diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   4v for rectifier tube (http://www.diyaudio.com/forums/tubes-valves/123162-4v-rectifier-tube.html)
camotecue 16th May 2008 02:11 PM
a silly question: what will happen if i use a 4v supply for a 5v specified rectifier like a 5y3 or 5u4g tube?
larry
Sheldon 16th May 2008 02:27 PM
You can probably get away with it, but only if you are drawing well under the maximum current for the tube.
Sheldon
camotecue 16th May 2008 02:47 PM
4v
thanks.
Miles Prower 16th May 2008 10:46 PM
If you under power the filament of a power diode, you will lose Isurge capability, and increase Vf. It's not a good idea, especially if your design is bumping against the max ratings.
It'd be better to get a proper filament xfmr for the type.
sorenj07 16th May 2008 11:07 PM
A small 5V 2A transformer (only 10VA) is worth it for a 5AR4/5Y3 type.
camotecue 19th May 2008 02:38 PM
4v
thank you guys. i better ask my winder for a new transformer.
kevinkr 19th May 2008 02:51 PM
Re: 4v
Or possibly use a 4V rectifier tube... :D (Some rare German and English types, look on eBay)
Sheldon 19th May 2008 03:08 PM
Re: 4v
If you are not pushing the rectifier to its current limits, don't worry, try it. Your 4V winding may give you something a little higher than 4V, and virtually all tube are rated at least +/_ 10%, so 4.5V on the filament would be within normal rating anyway. You don't have to try your best tube - 5U4G's are cheap and readily available.
Sheldon
Geek 19th May 2008 07:22 PM
A pair of unloved 3V damper tubes with resistor in the heater would also work if you're concerned.
Cheers!
Klimon 20th May 2008 08:49 PM
Better not to use it; 5u4g has excessive heater current draw (3A vs. 2A for e.g. gz32 and gz34) which will further decrease your voltage under load.
Simon
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
