Power transformer for 6883B tube uses?
Old 14th May 2008, 04:13 PM   #1
diamondsouled is offline diamondsouled  Canada
diamondsouled's Avatar
Default Power transformer for 6883B tube uses?
I just inherited a truck load of old 60's Marconi Ch 25 base radios, 6 of em! They have a huge power transformer that powers a pair of 6883B beam power tubes:
http://www.mif.pg.gda.pl/homepages/f...49/6/6883B.pdf
Would these trannies power 6L6s, EL34s, 6550s, as well?
Cheers
Lar
Old 14th May 2008, 07:52 PM   #2
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Assuming that these were about 125-150W output, the supply might be about 600V @ 400 mA intermittent duty. The same transformer might give 450V at 400 mA continuous with a choke input supply - plenty for a push-pull 6L6 or EL34 amp. If it's a voltage doubler supply, it won't be as useful, maybe too low with a bridge, too high with the doubler...
Power transformer for 6883B tube uses?Hide this!Advertise here!
Power transformer for tube experiments ErikdeBest Swap Meet 0 7th March 2009 02:37 PM
power transformer rating and tube current - SimpleSE cbutterworth Tubes / Valves 17 12th June 2008 10:54 PM
WTB: tube amp power transformer(s)... klm1 Swap Meet 0 30th June 2006 04:58 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 08:57 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
