| diyAudio Sponsor | ||
#41 |
also try switching off lights and all other appliances...
#42 |
The other amps that are quiet have a different design than this amp so the fact they are quiet and this one hums doesn't prove anything .As to why the hum varies from one side to the other,I don't know.Anyway at this point I am grasping at straws as to the reason.Try a different location,that will prove its is or isn't coming from the power line.If it is we can then add ckts to elimate the hum and we will know for sure what the problem is.
#43 | |||
O.K. So I did some further tests.
I did try SY's floating heater circuit Idea anyway, and this actually increased the buzz considerably, although this time the left and right side gave same level of buzz. This time I didn't try ceramic cap bypass. Finally I also switched left and right interstage transformer and buzz did not change either. So for the next step, I'm considering to change 210V diodes and every parts that is directly connected to input 12AX7 tube. ( Since taking out the input tube removed the buzz) But before that I would appreciate it if some one could provide info on how to test the power supply transformer and chokes.... By the way, could a bad tube socket cause a buzz? |
#44 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#45 |
RK, I had to chase my tail a bit when I constructed my current main amp... all the conventional routes of wisdom failed... I ended up doing the following for an amp that was buzzing for months...
Isolating all sockets from the enclosure. Use thinner wire from RCA socket to In- Add an intentional ground loop--- another wire from In- RCA socket to the power ground star...In my case this was the ground pin of the ICE socket (external AC supply). It is dead quiet now... I think getting the buzz equal on both channels is a step closer to finding your problem... I still think if the amp worked before, some component has given up or is in the process.. I would start by suspecting capacitors... many can safely be removed while testing to see if the problem persists... |
#46 |
Sorry to hear my idea of trying it at a friends place made no difference in the hum but we now know that its not a dirty A/C line trouble so we made some progress.The fact that it origionally had no hum and now has hum would seem to indicate a faulty part,most likely a capacitors.Im out of ideas.
#47 |
Was the side that had the buzz the V6 side?
Troubleshooting without a scope is a challenge!
#48 | |
#49 | |||
When i connected ICE socket earth to circuit ground, I hear a LARGER hum. In my amp, main earth is left disconnected and enclosure is connected to the circuit ground. What do you mean by external AC supply? My wire from RCA to main circuit is 24Gauge. What was yours? Quote:
Please let me konw what you think. If you think what I posted above is right, the only cap that is physically closer to the Left 12AX7 than right 12AX7 is 100/400V decoupling cap on the main circuit. But this should not generate ripple/ buzz. Am I right? |
#50 |
Didn't you already bridge this on with a good one? If its bad it will definately cause hum but in both channels.
| 4 ch esp p3a psu Buzz | kjb | Solid State | 7 | 4th August 2008 11:53 AM |
| Buzz in new amp... | chrish | Tubes / Valves | 10 | 20th February 2008 04:06 AM |
| Melos triode and computer as source: BUZZ BUZZ BUZZ | zigo3 | Tubes / Valves | 4 | 28th November 2007 02:11 AM |
| hum/buzz with pot all the way up | woodturner-fran | Tubes / Valves | 19 | 24th September 2007 12:31 PM |
| A-75 buzz | Dave Varner | Pass Labs | 3 | 15th February 2002 01:30 PM |
| Page generated in 0.11801 seconds (80.79% PHP - 19.21% MySQL) with 11 queries |
