| diyAudio Sponsor | ||
I am a little stumped, not sure of grounding with single tap secondary...
I have no idea how the transformer primary is wound but that side has an earth wire as well as the 2 AC connections... The secondary for the HV and the one for the heater are not centre tapped... do I just connect the negative side of the bridge rectifiers to ground?
#2 | |
Jorge |
| Use a single secondary x-former as dual PSU? | pixworld | Chip Amps | 7 | 9th March 2009 12:32 PM |
| Single ended transformer grounding question | Captn Dave | Tubes / Valves | 1 | 29th January 2009 05:41 PM |
| two seperate single secondary toroids = combined center tapped transformer?? | gbolly | Chip Amps | 5 | 5th November 2008 03:56 PM |
| Grounding Idea for single opamps | Franz G | Chip Amps | 10 | 28th December 2005 02:29 PM |
| LM3875 kit grounding, optimal grounding for separate amps and psu? | findog | Chip Amps | 9 | 16th May 2005 09:27 PM |
| Page generated in 0.07211 seconds (74.03% PHP - 25.97% MySQL) with 10 queries |
